Closed Thread
Old 08-28-2011, 01:36 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Default SBC 406 with LT1/T56 Transmission
This engine & transmission is great for 67 to 69 Camaro or 68 to 72 Nova.. The transmission was in a 68 Camaro..
406 SBC- original Chevy block
9.1 compression ratio
Lunati Rotating assembly -internal balance
Professional Products Harmonic balancer
Splayed main bearing caps
AFR cylinder heads- 195
Crower Cam- Lift int 540 exh 565 Duration @.050 int 236 exh 244 LSA 114 deg Hyd/Roller
Cower Hyd/Roller Lifers & rockers
MSD Distributor
Aluminum water pump
Power Master High torque starter
Edelbrock Air gap intake with 750 HP Carburetor or DFI complete system
Racing engine Analysis - 526 HP & 526 TQ
LT1 /T56 Transmission Rebuilt by Rockland Gear- 20k miles on rebuild
Mcleod billet flywheel with clutch & pressure plate
ATS transmission support
Driveshaft
Asking 8500.00 for everything.. have an option on intake systems.. only one set up goes with engine
Have a new set of Dynatech headers for Camaro/Nova.. additional 400.00
Cris Gonzalez
Old 08-28-2011, 09:45 PM
CamaroBill's Avatar
CamaroBill CamaroBill is offline
Are you willing to separate? IF so, how much for the engine and headers? Bill
Old 08-29-2011, 06:02 AM
Cris@JCG's Avatar
I will let go the engine with headers for 6800.00
Cris Gonzalez
Old 08-29-2011, 06:03 PM
Rick D's Avatar
Rick D Rick D is offline
Question
Cris, how much for the trans setup??
Rick
Old 08-30-2011, 10:23 AM
Cris@JCG's Avatar
Rick- I only really included the trans set up to sweeten up the deal for somebody looking for a complete drivetrain.. If I just sell the motor by itself.. I am good with that.. Trans can be converted for an LS set up pretty easy.. & can use it on one of the shop builds
Cris Gonzalez
Old 08-30-2011, 07:47 PM
Rick D's Avatar
It's good Cris thats is what I wanted to do. Oh well I will keep looking.
Rick
Old 08-15-2012, 02:01 PM
Cris@JCG's Avatar
I have to move this motor.. have an over stock of engines sitting here @ the shop...
Engine 4500.00
Trans set up 1200.00
headers 400.00
MSD Distributor
Aluminum water pump
Driveshaft
Cris Gonzalez
Closed Thread
