Old 10-16-2012, 06:45 PM
Default reinventing my dash
I have a 68 Camaro and really don't like the dash layout. Has anybody have any info on installing a dash from a 70,71 Firebird style dash? Also are my speedo and tach 5" ?
Thanks, Kevin
Old 10-16-2012, 09:14 PM
DETON8R's Avatar
DETON8R DETON8R is offline
I have never seen a second gen F-body dash in a first gen however I have seen a 4th gen dash in both a first and second gen.
Width is about the same, so it should fit. Will need to rework the vents for the defroster, no worries there.
Dash swaps sometimes make window crank problems on the doors, you might want to check that out before you start the swap. Or if you are going to run electric windows it won't matter.
DETONATOR - 69 Camaro RS
Old 10-17-2012, 05:25 PM
Thanks for the info
Old 10-28-2012, 10:20 AM
brandonc707 brandonc707 is offline
yes, the first gen dash holes are 5"....... I have autometer 5" tach and speedo in the factory holes. VERY easy to do
Old 11-16-2012, 12:25 PM
esenior esenior is offline
If your main concern is the gauges, then check out New Vintage. I recently installed a set in my son's 67 Camaro. They bolt right into the stock gauge carrier and provide a total of 6 gauges (3 gauges per gauge)
http://www.newvintageusa.com/1969.html
If you are talking overall dash layout, then this won't help, but I do have a 4th gen dash I'm looking to get rid of!
Old 11-16-2012, 01:27 PM
PSV's Avatar
PSV PSV is offline
Mayhem has what looks like a 69 dse dash in it.
Old 11-16-2012, 01:28 PM
PSV's Avatar
PSV PSV is offline
there a pic on this page. 67 with 69 dash.
https://lateral-g.net/forums/show...=36652&page=67
Old 11-16-2012, 03:27 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Well, the holes are actually 4 7/8", but the 5" gauges will work. Just not as well as the new vintage gauges. I have the 68 Series 3 in 1 gauges, but I had it made custom. New Vintage gives you plenty of options.
http://www.newvintageusa.com/future.html
The 67-68 Camaro dash can be made to work. Just takes some imagination to do it. We totally re-worked the center dash, but tried to keep the look of first gen camaro. I have seen Corvette dashes in a 68 Camaro.
http://www.lingenfelter.com/vehicles...68-camaro-rs06
There is loads of options, but not sure if second generation camaro would look right. Look at some European cars, there is other options there as well.
