Old 01-04-2013, 06:51 AM
barrrf's Avatar
barrrf barrrf is offline
Default A-Body Front Suspension Questions
Im finally able to start piecing together some suspension components after a great holiday. Im starting with the front and am not sure what my best choice would be as far as getting the car lower.......
I plan on purchasing Coil Overs next year. But right now Im either going to buy lowering springs or lowering spindles. Which option would be the best?
I was leaning towards 2" lowering tall spindles to achieve that camber sweetness as opposed to just tossing some springs in there on stock spindles. Does this make sense?
'69 Chevelle Malibu LSX370, 4L80E, Brembos, hydroboost, 12 bolt, c/os, etc.
You can call me Bart
Old 01-04-2013, 12:01 PM
barrrf's Avatar
After some hours of searching it looks like the best way to go would be with stock height tall spindles and lowering springs.
Thoughts?
Old 01-04-2013, 03:02 PM
TMIProducts's Avatar
TMIProducts TMIProducts is offline
Thoughts?
Maybe the lowering spring will give you more of a firmer/performance ride.
But if it were me, I'd do the drop spindle. That way you maintain the smoothness of the factory ride. Then do the tall ball joints to correct geometry.
www.tmiproducts.com
Our 66 Chevelle Build Thread:
http://www.chevelles.com/forums/showthread.php?t=285211
Old 01-04-2013, 04:24 PM
Supporting Vendor
If you plan on going coil over in the future why not use a tall, drop spindle?
This will give you the drop you want, the added height will correct the geometry, and you'll have a head start on the coil over project (later you can just add upper and lower control arms with coil overs and be done).
The only thing you'll want to watch is that you don't reach ball joint bind using a tall spindle and the stock arms.
If you need to replace the OE shocks you can use our new RQ mono tube dampers that have a 1,000,001 mile warranty.
http://www.ridetech.com/store/muscle...hash=V270.V328
Skunk Werks
Ridetech
www.ridetech.com
Old 01-05-2013, 01:18 PM
dug dug is offline
what he said.
Doug
1970 chevelle, 383/turbocharged/carb'd/5 speed.
Old 01-07-2013, 10:53 AM
barrrf's Avatar
Actually, Im experiencing bind right now when in backing up at full crank. I assumed it was bad bearings. The problem is, work was done on the front end by the previous owner and I have no idea what components he used. I was just going to go ahead and replace the spindles in case the components used were of subpar quality.
Current shocks are those funky Edelbrock jobs. I dont know if I like them.
Could it be ball joints that Im feeling binding?
Old 01-07-2013, 11:06 AM
barrrf's Avatar
To verify, the RT website states the spindles are compatible with only aftermarket tubular control arms. True?
Old 01-07-2013, 01:49 PM
black67malibu black67malibu is offline
I've been speaking with the guys from SC&C about my 67 chevelle. I was talking with a guy named Marcus and he gave me some great info for my car. Might be worth a phone call.
