Old 11-13-2013, 08:37 AM
fillpot fillpot is offline
Default G-link with 12-200 spring
Guy's i no this has been touched on a thousand times but im going to order some new springs to lower my car down a little more (69 camaro) and was wondering about some spring suggestions,it has a 12-200 in it now and was leaning toward a 8-200,the car is just street driven and i also do some 1/8 mile drag racing no autocross or anything,car just needs to set a little lower and i've got the shock mounts in the lowest setting.THANKS!
Old 11-13-2013, 08:51 AM
dhutton dhutton is offline
I would have thought you would change the rate to lower the car, not use a shorter spring of the same rate. But I am usually out in the weeds... Let's see if one of the experts weighs in....
Make sure your shock is roughly centered in it's travel at ride height when you are finished. If it is right now then you cannot make it much lower, expecially for a street driven car.
Old 11-13-2013, 09:26 AM
Yea that's me to it can be confusing,like you said lets see if we can get some expert opinions and a softer spring sounds better because the car is stiff as hell but it could be in the adjustment also(QA1 double adjustable shocks)but there on the softest setting.THANKS!
Old 11-13-2013, 10:51 AM
Musclerodz's Avatar
you would also need to run shorter shocks if you want it lower. otherwise you could bottom out the shocks.
Mike Redpath
Musclerodz & Customz
facebook page
Old 11-13-2013, 02:31 PM
Rybar's Avatar
Rybar Rybar is offline
Here is my setup with a shorter spring. I'm not sure if the the shop that did the install used 8" or 10" springs but I measured and photographed them compressed.
https://lateral-g.net/forums/show...&postcount=385
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 11-13-2013, 03:17 PM
Rybar thanks for the pics,i've searched a lot of threads on this and it seems that some have used the 8in spring and it worked fine may just try it and see, if it doesn't work out want be the first time I've made a mistake with this build LOL.Btw love your car it's a work of art for sure,man i wish could get a pair of those tailpipes guessing they were made in your part of the world.THANKS!
Old 11-13-2013, 04:00 PM
Rybar's Avatar
NP glad I could help out I wish I knew this before buying my setup. Yes the tailpipes were custom made locally. The tank is a stock width Ricks tank that is not dog eared on the corners. So for those wondering it can be done, this is with 2.5" tailpipes though.
1969 CAMARO RS
Old 11-13-2013, 08:06 PM
The minimum bump travel you'll get away with is 2.25" without possibly compromising a shock. I'd move the mount and keep your shock travel.
Old 11-14-2013, 07:18 AM
One thing that bothers me also is the stiffness,it's super stiff in the rear and also the spring seat is at the very bottom of the shock.It's been pretty cold here the last couple of days and been working late so maybe today i can check it out a little futher and post some pics.THANKS!
Old 11-26-2013, 09:34 AM
Chassisworks Chassisworks is offline
Supporting Vendor
Fillpot, There are several ways to lower the car without making such a drastic spring change. Let's see if we can't get this figured out. Here are some questions that I would ask if we were on the phone.
How much lower are you trying to get the car?
With the suspension loaded, what does the shock measure from eye to eye?
With the suspension loaded, what is the compressed length of the spring?
Do you have single or double adjustable shocks?
Do NOT change to an 8" spring. It will be close to coil bind by the time it accepts the full weight of the car. This is potentially damaging to the shock.
