Old 02-18-2014, 06:06 PM
DRJDVM's '69's Avatar
Default OBD II scan tool for iPad etc?
I've seen quite a few at SEMA etc, but was wondering if any of you guys had experience using any of them....
For years I've had a program on an old laptop that worked for trouble codes and reading real time data. But now the laptop is pretty ancient and so is the program....its not working very well, crashes, doesn't seem to work with my newer cars etc
When I get a Check Engine Light, I'm trying to check the codes to see if its something I can fix ant home or need to take it in..
So its time to upgrade...looking for a home hobby type deal...not some expensive professional set up...
Old 02-19-2014, 05:39 PM
Cread01 Cread01 is offline
I got an app called torque for my smartphone, and a cheap obdII bluetooth setup and it's awesome. I have read codes reset them and it also gives you a few other options like 0-100 times and stuff like that. I have less than 15 bucks into the whole thing.
Old 02-22-2014, 06:57 AM
Gaslight Gaslight is offline
I use the torque app on my Android. I also bought one of the cheap OBDII plugs but it would not work with my 02 GMC Sierra. I found out it would not work. I had to buy one that was about 40.00. I found out some don't work with all applications. So make sure which ever one you get works for your application.
Jake
1973 Nova SS
Old 02-23-2014, 01:26 PM
chicane's Avatar
chicane chicane is offline
I use this BT link device (mainly because of it's PID update rate and encrypted BT connection) and have a few Android apps that interface with a Nexus 7 tablet that I picked up. I have used this combination in multiple vehicles... I just unplug one and plug it into another. The only thing with that is if you want the expanded PID reading for specific manufacturers (Ford, GM, etc) it will run about $10 for each. Not a deal breaker... but none the less.
The software is going to be device specific... but I think out of all the apps I use... they all interface with Apple products and are available in both the Android market and the Apple store.
The Dash Command app has the best accelerometer interface:
And I have found that "Torque" has unlimited 'themes' to display the monitored information. I find myself using the "Racing Meter" theme the most for just driving around and monitoring the available PIDs.
Old 02-23-2014, 06:32 PM
Originally Posted by chicane View Post
Put that in the dash with a bezel around it ! Beautiful and amazing technology ! Thx for the info !
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 02-23-2014, 08:51 PM
CarlC CarlC is offline
Tommy! Good to hear from you.
I use similar tech. Dash Commander has a ton of functionality and is pretty reasonably priced.
http:www.vaporworx.com
