Old 07-14-2006, 10:05 AM
ArisESQ ArisESQ is offline
Default Did a little test fitting last night...
Just thought some of you guys may be interested...
A friend of mine has a set of 18x10 w/ 5.5 inches back, and a set of 295. We were curious if they would fit at all on my car (67 camaro).. and well... to my surprise they did. there was actually about an inch of room between the inner fender and the tire.
all i have done to my fenders is have the lip completely trimmed off, and the fender mildly pulled with a fender rolling tool. an offset of 5.75 to 6 would have probably been ideal, but the 5.5 DID fit without issue.
also, my car is lowered in the rear via hotchkis leafs, and it looked like it could go about 1 to 1.5 inches lower without rubbing.
Old 07-14-2006, 09:56 PM
aonghus's Avatar
aonghus aonghus is offline
now drive the car and see if they rub, bottom the suspension out on a big dip or driveway, the same way you would driving the car.
Old 07-16-2006, 10:50 PM
yea i should go do that. BUT, he has no more room than i did, and he drives his car way harder than i do, and he doesent rub at all. so i dunno. there definently should be a little more testing and stuff, but so far as i can tell, they fit fine.
Old 07-17-2006, 05:13 AM
6D9 6D9 is offline
Any pics???
Old 07-17-2006, 12:21 PM
Here are the only 2 pictures i actually have, and they arent really that great.
there is just above an inch between the inner fender and the tire, so like i said, an offset of 5.75 or 6 would pull the wheel into the fender enough that there would be no issue with the fender lip.
Old 07-17-2006, 05:34 PM
zbugger's Avatar
zbugger zbugger is offline
Hey, what part of the Bay Area are you in? And what Bay Area? I've heard of three of them. Anyway, if you are local to me, I'd be willing to take a look and maybe show you what to look for. Pictures suck for doing this kind of thing unless they're taken right. Here's an idea though. Look under the car from the rear and take a picture up into the wheel well. That may help us that can't stop by and look get a better idea of what you've got to work with.
