Old 05-22-2006, 04:32 PM
markss28 markss28 is offline
Default Nova wheel ?
Ok I know this question has probably been asked about a thousand times but I really need to know within the next day or 2. How big of wheel can a 72 nova fit in the back. I would like to put on a 18x10 but I understand they do not have the same room as a camaro. Any help will be greatly apreciated. Also I would like to know what the largest time combo I can fit.
Never Stay Stock
Old 05-23-2006, 07:14 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
You can read the specs in my PHR link in my sig. My rear tires are very tight in there, and they do rub a little during articulation. I think a 275 is max for width. I'm running an 8" wheel. A 9" wheel may work, not sure on that 10" wheel though.
Old 05-23-2006, 11:25 AM
USAZR1's Avatar
USAZR1 USAZR1 is offline
A 9.5" width wheel will fit with a 5.75"-6" backspacing. Some guy on the P-T Forum installed 18x10's with 275's and 6.25" backspacing on the rear of a 70 Nova. Seems like the 68-72 Novas have more room than First Gen Camaros.
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 05-23-2006, 11:49 AM
MarkM66's Avatar
I'm running 5.5" bs, and like I said it rubs sometimes, so if you want to try to run more then 5.5" bs, best of luck to you. I have about 1/2" between the tire and outer wheelhouse, all stock, non modified. I'm very skeptical about that 6.25" bs. On my car you'd be replacing tires really soon, if it got out of the driveway.
Old 05-23-2006, 01:14 PM
Hdesign's Avatar
Hdesign Hdesign is offline
Try this link: http://www.2quicknovas.com/6874.html
It's my understanding that you can slip by with maybe a 9" wide wheel with some generous backspacing. I think if you go wider, you may have to mini-tub and roll the fenderlip.
Ben Hermance
Hermance Design
My Facebook
Old 05-23-2006, 02:20 PM
MarkM66's Avatar
I just went and did some measuring on mine. I have almost exactly 5/8" between the tire, and outer wheelhouse. I tried putting a 7/16" (which measures 5/8" od) socket between the two, and it fit very tight.
Old 05-24-2006, 06:54 AM
NvrDun71 NvrDun71 is offline
Mark,
Not to deviate from the original thread here but I am also about to a 17" rim/tire swap on my 71' Nova. Just have a couple questions for ya. First did you have to run a rear shock that doesn't have the upper body on it to run the 5.5 backspace. I am planning on an 17x8 wheel with a 255/45/17 to keep it a little conservative and wanted to get your opinion on what the best backspace would be. I know most run the 4.75 with an 8" rim however I would think a 5.00 or a 5.125 would be a little better tucking the rear tire further underneath the car as I am going with some QA1's in the rear w/out the upper body. In your opinion is it a good or bad idea to go w/ tha extra backspace? Also have you rolled your fenderlips at all or are they still unmodified. Thanks for any insight you can provide.
71' Nova - LY6, T56
