Old 03-01-2005, 08:31 AM
Default Rod Saboury's new car
This isn't a Pro Touring build at all, but I thought it was interesting anyway.
Rod Saboury’s REAL 6 second street car – part 1
by Mike Goodwin
Mention the name Rod Saboury to one of your racing buddies and you’re sure to get an interesting response. While researching this article I encountered varying views on Rod and his numerous projects. From accolades in main stream media to disdain on Corvette restoration message boards this man has proven one thing, he is able to craft attention grabbing cars that leave a lasting impression. Another thing I learned about Rod is that his enthusiasm for a project is infectious. When we discussed his latest project he was like an expectant papa pacing the floor of the maternity ward. I just couldn’t help but get wrapped up in the excitement.
Currently on a chassis table at the famed Lowdown Hotrods of Cambridge Ontario sits Rod’s latest project a 1963 Corvette split window coupe. Although an original ’63 body shell and dash are being used you Corvette purists can breathe easy, they came from a chopped up donor that was destined for the scrap heap. With this ‘Vette Saboury is once again pushing the envelope with his design. “I want to have the first 6 second, 200 mph REAL street car” stated Rod “One of my goals is to qualify for one of the fastest street car races and then go cruising with all the locals that night. Lets see if any of those guys with the so called ‘Fastest Street Cars’ will join me, NOT!” Some pretty powerful words that by all indications he will have no problem backing up.
In order to accomplish his goal Rod plans to incorporate a few out of the ordinary design concepts. To start with the factory wheelbase on a ’63 Corvette is 98”, somewhat short for safe handling at over 200 MPH. To ensure the car will track straight it was lengthened to 110”. That’s where the design became interesting. Instead of just adding a stretch to the front end like most car builders Rod made an effort to keep the car looking as stock as possible. To accomplish this he commissioned bodyman Frank Morawski of Baltimore MD. to section the main cabin. Frank cut the car in half and added 4'' in the roof behind the doors. He did such a good job that a Corvette aficionado would be hard pressed to notice the alteration. Rod also had the rear end centerline shifted back 2'' thus requiring only a 6” extension to the front end. Additionally the rear quarter panels were widened and raised to accommodate the 34” of Mickey Thompson rubber that will be housed beneath. “Without a side by side comparison to a stock ’63 the body will appear factory” stated Saboury.
The Vette’s chassis incorporates a chrome moly double frame rail design with a Funny Car style front half. Rod went to this extent because he plans to make the car NHRA legal and pass the advanced ET chassis certification for cars that run quicker than 7.50. With the expected 2000+ horsepower that will be needed to put this car comfortably in the sixes Chassis builder Tom VanDerGeld, owner of Lowdown Hotrods, incorporated a unique rear end setup that will help it launch straight and level. A full floater 4-link design that utilizes no wishbone or panhard bar will be used. “ It’s similar to the one we used in Gary Irving’s ’37 Chevy Nitro Coupe” stated Tom.
Rod’s next big leap in design strategy was to enlist the talents of famed engine builder Mike Moran. Under the hood will throb another unique combination, a 400 Chevy Small Block with Big Block heads force fed by twin 80mm Precision Turbos. The specifics of the engine are so secret that Moran was reluctant to even let VanDerGeld use the engine for the layout of the front end chassis setup.
With the expected monster horsepower ratings from the Mighty Mouse the only transmission Rod considered was a Lenco. A 4 speed version will soon be nestled between the rails backed up by a Ram triple disk clutch and Trick Titanium bell housing. “We decided to go with a triple disk to lengthen the lifespan of the clutches since I plan to cruise this thing. I even plan to do a leg of the Hot Rod Power Tour. In fact this car is being outfitted with all the necessary street equipment including power windows hide away head lights, and I’m even trying to figure out how to get the air conditioning to work! It’s been a while since I have had a car of this caliber and I’m spending extra time on the fine details. I also need to point out that this project would not have been possible without the assistance of Moran Racing Engines, Lowdown Hotrods, Mickey Thompson Tires, Weld Wheels, Flowmaster Mufflers & Auto Meter Instruments.”
To finish things off Rod once again enlisted the talented artist David Peters, the designer of all of his previous paint creations, to come up with a head turning scheme. “I hope people have a hard time accepting this design. If they like it that means they’re familiar with the design concept and I want this car to be unique”. Judging from the past if anyone can build a true 6 second street car that people will not soon forget, it will be Rod Saboury.
Old 03-01-2005, 08:40 AM
body
engine
rear end
this is a small block!
Old 03-01-2005, 08:53 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Now that's awesome. I'd sure like to know more about that motor combination.
Anybody know Rod?
My LS7 69 Camaro
Old 03-01-2005, 09:07 AM
BC69's Avatar
BC69 BC69 is offline
This reminds me of TwinStings Corvette with the creature comforts. I mean if you're gonna put all the time, fabrication, and money into a car like that...mine as well be nice and comfy when you drive it. Thats insane!
Tim
In memory of those gone before us
In gratitude for those who care.
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Used to see Rod race his 56 Corvette at Memphis Motor Speedway way back in the NMCA days. Really nice guy as I recall. Good to hear about him again.
Jim
Old 03-01-2005, 10:05 AM
trapin's Avatar
trapin trapin is offline
Is this the same guy that built that black 2nd gen Corvette that won Street Machine Of The Year in the early 90's and got all kinds of press. His name sounds familiar. I think the car had a full front clip that flipped forward. Awesome car.
I see Moran Racing valve covers on the engine. Would that be Mike Moran's company? We used to street race against Mike and his boys back in the day. He helped build a car for a buddy of mine that he dubbed Casper Jr. Casper was Moran's 200 mph '95 Camaro.
6 seconds? That'll make your brain hit the back of your skull.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 03-01-2005, 10:09 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Are those "Little Chief" heads?
Old 03-01-2005, 10:29 AM
907rs's Avatar
907rs 907rs is offline
Could very well be, although I don't remember that particular car.
If memory serves me right, he's a roofing contractor from the east coast and always ran 'vettes in the early days of the NMCA. His cars were known for their "show" quality, but could run the numbers effortlessly.
Bill
Old 03-01-2005, 10:47 AM
MarkM66's Avatar
He had a blue '63 split window (or very similar year to it), with an LS-1 in it and tubbed out. I saw it at the Special Events Street Machine nationals in Indy, I think the year 2000. I'm sure he won quite a few awards there.
He never won GoodGuys Street Machine of the Year.
Old 03-01-2005, 10:51 AM
Lateral-g Moderator
Default car
Six seconds, WOW. That is so fast I cant imagine what that feels like!!
