Old 06-05-2014, 12:45 PM
69greyghost 69greyghost is offline
Default Guys I wanna run gen 4 camaro brakes what am I missing
Guys look I know this has been beat to hell most likely, I know I have even talked about it but I am hoping to get the answer quickly instead of having this take a long time to get the answers I need. Here is what I have, generation 4 98-02 v8 brake calipers and rotors from and rear, a 98-02 rear end for backing plates ( still gotta take those off), russel brake lines from summit part number 692280, machined drum hubs for the front, front brackets and rear spacers ( I was told aia needed some spacers for my axle). I guess my question is what am I missing and what do I need for an e brake on these brakes? Thanks in advance guys for any and all help.
Old 06-05-2014, 04:14 PM
cables....are you running staggered shocks in the rear? The right side will have clearance issues.
Old 06-05-2014, 06:47 PM
rickpaw rickpaw is offline
If you have disc spindles, you will also need spacers to mount the brackets as well.
Tu Ho
Old 06-06-2014, 11:48 AM
I was told that was only in 67 camaro's not 69, is this correct?
I have drum spindles that have been turned down.
Old 06-06-2014, 12:22 PM
geberhard's Avatar
geberhard geberhard is offline
Anthony,I think what Tu was mentioning is the spacer between the spindle and the LS bracket since you have disc brake spindles. They are about a 1/4 nch round spacer, I will send you a picture.
For the ebrake cables, someone posted here before on how to modify or a few part numbers. I think Lokar may have some as well.
Check this thread out:
http://www.camaros.net/forums/showthread.php?t=161383
Gui
Old 06-06-2014, 12:42 PM
geberhard's Avatar
Anthony, this may help. Did you buy the brackets from Joe with the spacers?
The spacer will mount between the bracket top hole (see pic) and the spindle:
If you do not have the spacers, give me a holler, I think I bought two sets from him. You may be able to get away with a thick washer.
For the rear, you can run a spacer similar to this, to center the caliper:
Give me a holler if you get stuck.
Old 06-06-2014, 12:24 PM
67's are not staggered, staggered arrangement will require 2 left sets or move the shocks.
