Old 08-15-2014, 06:40 AM
vstol vstol is offline
Default hard line to an fittings
I 'm getting ready to run my fuel lines and would like to run stainless 1/2 as much as I can to a Teflon braided line to the LS connection as well as the fuel pump and filters. Whats the best way to do this, the LS is FI so 60-70PSI required. Build below, thanks
https://lateral-g.net/forums/showthread.php4?t=44704
Old 08-15-2014, 08:26 AM
Musclerodz's Avatar
Its simple, you will need a 37* flaring tool, tube nut, tube nut sleeve, and an union fitting. for the hose side, you just need to buy the appropriate hose and fitting that you can assemble, or measure how long you need it and have a shop crimp a set of ends on.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-15-2014, 09:33 AM
dhutton dhutton is online now
This is what I use to go from hard line to AN. Probably not the most elegant solution but they work:
http://www.summitracing.com/search/p...tube%20fitting
Old 08-15-2014, 10:48 AM
thanks I knew about the 37 degree flare I was wondering if there is another solution besides flaring. I would imagine it would not be as secure
Old 08-15-2014, 10:49 AM
OBeer-WAN-Kenobi's Avatar
I think something like this would also work:
http://www.mcmaster.com/#5182k457/=taj967
I was going to use them since you don't need to flare anything but decided just to use PTFE lined braided hose instead of hard line.
These are rated for 2,100 PSI so they should be pretty secure.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 08-15-2014, 11:34 AM
They are secure. That type of fitting is widely used in other applications. I have used them several times without issue.
Old 08-15-2014, 11:42 AM
Aren't those just for aluminum tubing though? It doesn't say anything about stainless tubing in the descriptions, just aluminum tubing. I would think that would make a major difference.
That's what steered me towards the yorlok and swagelok style fittings like I linked above before I ultimately just went with PTFE lined braided hose. I know for a fact the yorlok and swagelok fittings hold tight on stainless as we use them with stainless tubing in high pressure tester applications where I work.
'69 RS Camaro
Old 08-15-2014, 11:53 AM
They are designed for aluminum tubing but I have used them on transmission lines (90 psi dead head pressures) and mechanical fuel pump applications with steel line with no issues. Whether it works with the harder stainless line is what is not known. 70 psi fuel pressure you gonna wanna flare the tube.
Any particular reason you are wanting stainless? 1/2" stainless isn't a whole lot of fun to work with.
Old 08-15-2014, 12:53 PM
Musclerodz's Avatar
That is a compression style fitting. I am sure they work fine, but not what I prefer to use.
Mike Redpath
facebook page
Old 08-15-2014, 01:16 PM
I have used them on 3/8 stainless and I can tell you from experience that the ferrule is on there to stay. At least they hold a whole lot better than those Russell AN to GM fuel rail adaptors...
As I said not the most elegant solution but flaring 1/2 inch stainless is something that I can't image being all that easy to do depending on the flaring tool you have.
Your fittings were $30 each if I read it correctly. That gives me a little heartburn...
