Old 10-09-2014, 10:24 PM
frankv11's Avatar
frankv11 frankv11 is offline
Default Fitting al knoch deluxe panels
I know it's been done many times but how do you guys get these door panels to fit really nice on the door , after some massaging I'm still off !
They fit ok without the inner side window guide brackets. But there will not have whole lot of support on upper edge without them and not mention glass guide issues
That's a huge gap. almost an inch ouch!!!
They look good and I will make them fit but figure I'll ask before I start cutting on door
Old 10-10-2014, 10:13 PM
fishface's Avatar
fishface fishface is offline
Wow, that is a gap. I know many have used a heat gun on inside to make them conform a little better. Amazing they could fit back then but don't with 45 year newer technology.
Old 10-11-2014, 06:22 PM
Rod P's Avatar
Rod P Rod P is offline
isn't there a rubber door seal that fills that gap....I would double check that first....most early cars have a large weather fill front and back on the doors
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 10-11-2014, 09:24 PM
frankv11's Avatar
Good point rod. I'll look that up
Old 10-12-2014, 06:08 AM
dhutton dhutton is offline
The door weatherstrip has large molded ends to fill those gaps.
Old 10-12-2014, 03:56 PM
frankv11's Avatar
Yes the weather stripping does tuck under panel.
Daaaahh
Old 10-12-2014, 05:58 PM
Rod P's Avatar
Rod Prouty
Bangshift Stories
Old 10-12-2014, 06:03 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Frank,those Al Knoch panels are really nice and fit fairly well.
Old 10-12-2014, 10:34 PM
frankv11's Avatar
yes they are damm good looking, just left my mind some where else when I was working on them. they could use a bit of massaging so i'll slightly bend the two upper window guides that the panel clips on to. to lower panel a bit . and will also bend sheet metal on panel where it mounts on to them like the originals.. the perimeter retainers are way off and holes are kind of chewed up but they are overall very good where it counts.
Old 10-26-2014, 10:05 PM
frankv11's Avatar
Just got around to installing weather stripping , panels fit and look great. No need to bend brackets turns out to be my repop door outer top edge was off on front end by 3/4" ( not much !!!! ) no fun on trying to keep that top edge on check as it curves twice while trying to keep top flat and even. This is one of the reasons why it will get completely built before any paint.
