Old 02-17-2015, 04:35 PM
Snipe00 Snipe00 is offline
Default U-bolt or strap
I got a 12 bolt a few months ago and finally about to get a new drive shaft for my camaro. Now with this yoke do I use my old u bolts or straps? Notice how only one hole is threaded. Thank you
Old 02-17-2015, 11:41 PM
somebody miffed that one up and drilled the other hole...... since you are gonna get a new shaft anyways swap that yoke out for a 1350 version.
http://www.summitracing.com/parts/str-u1602
http://www.summitracing.com/parts/mor-85080
Old 02-18-2015, 10:09 AM
So you are saying he drilled out the other three threaded holes, could I just go ahead and dill out the last then use the u bolts you showed?
Old 02-18-2015, 02:05 PM
That looks like the smaller 1310 u joint yoke. I'd go larger 1350 since you haven't ordered your driveshaft yet.
Old 02-18-2015, 02:24 PM
Bad Bowtie Bad Bowtie is offline
I would be concerned that if the yoke was designed for a bolt to thread into it, that if you drilled it out and tried to use a u-bolt that the u-bolts nuts wouldn't have a flat surface to rest on. Most bolt style yokes on the backside are just uneven casting. I'm with Vince on an upgrade
BB
