Old 07-01-2015, 11:09 AM
Tim john--- Tim john--- is offline
Default Vintage Air (compressor) mounting brkt. opinions wanted.
Good afternoon all, I am looking for opinions on the after market A/C compressor mounting brackets for an LS-1 engine. The Vintage Air (Sanden 508) compressor mounts up high and I am aware of two mounts and I am sure there are others. What does eveyone reccomend. I know of the Holley 20-134 brkt. and that also requires a spacer # 21-2 or the Kwik Performance. The Holley is cast aluminum and looks factory, the Kwik Performance is flat stock aluminum with spacers. Should I be considering another brand, please chime in with your thoughts and experience. The rest of my pulley/drive system is factory stock 2004 GTO LS-1. Thank You.
Tim john---
Old 07-01-2015, 12:28 PM
Musclerodz's Avatar
don't use the kwik, they have a tendency to squeal because they don't line up perfectly. I prefer the holley bracket for use with factory brackets.
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-02-2015, 06:18 AM
130fe 130fe is offline
Thumbs up
Another vote for the Holley AC bracket. I am using it with the stock corvette serp setup and it works great and looks like it is factory.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 07-02-2015, 11:58 AM
rocketrod rocketrod is offline
I have the Holley bracket and it looks great, but mine squeaks. Everything is brand new and I have tried multiple belts, tensioners and idlers to no avail.
Rod
1969 Camaro - LS2/4L70E
Old 07-02-2015, 01:14 PM
Good info!! what belt did you end up with and did you have to add a Holley spacer kit?
Old 07-02-2015, 05:32 PM
Musclerodz's Avatar
Do you have the right kit with the right spacers? I have never had a holley bracket squeak.
Mike Redpath
facebook page
Old 07-02-2015, 09:17 PM
andrewb70's Avatar
I am a big fan of the Katech non spring loaded belt tensioner. Might want to give that a go...
Andrew
Old 07-03-2015, 04:18 AM
Yes, I have all the right parts and have even confirmed it with a Holley tech rep.
Rod
Old 07-03-2015, 10:36 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I used the Kwik on My LS7 build and Holley on my the last LS3 I did and am using the holley on my new build.
Another Vote for Holley
btw I used the entire Holley Front Drive from Jegs on my current build.
Old 07-06-2015, 04:05 AM
Thank You everyone for chiming in, when I order my Vintage Air unit I will be ordering the Holley set up. This forum is a great resource for real world applications. Thanks so much.
Tim john---
