Old 04-21-2014, 03:57 PM
69hugger's Avatar
69hugger 69hugger is offline
Default Best semi-gloss black aerosol paint?
For many years, I used Krylon semi-gloss as the go-to paint for engine bay, chassis, and other parts needing the semi-gloss treatment. It sprayed beautifully, dried fast, and gave the perfect sheen. It was almost impossible to screw it up.
My current need is to paint the taillight panel on my '69 Camaro. It obviously needs to look better than the under hood areas.
The "new" formulation (p/n 51613) of Krylon "satin" black is slightly glossier than the previous formulation, and doesn't spray as smoothly, leaving spatters. I have tried several cans with the same result. The biggest problem though is it is just a bit to shiny.
I read elsewhere that all the paint manufacturers were forced to reformulate due to emissions regulations, etc. Now these sprays don't seem to work as well.
So now what?
Krylon does have "semi-flat", p/n 53565, which is between satin & flat, but I cannot find it locally. And I'm not sure what it looks like.
I really don't want to spend big $$ to paint 2 square feet and wait days for it to arrive, so I am hesitant to go to Eastwood.
I am not historically a Rust-O-leum fan because it used to spray poorly and took forever to dry. Maybe that has changed?
Anybody have a suggestion as to the best product (readily available) to use for this?
Thanks in advance!
Bill
Old 04-21-2014, 04:26 PM
ADiCarlo ADiCarlo is offline
I've used duplicolor in the past. I like the fact that they have online tutorials, typically make a primer base for there paints and have a good range of color.
I used it to repaint my motorcycle frame and engine - came out real nice.
I'll see if I can dig up some pictures tonight.
Old 04-21-2014, 07:08 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
I like SEM Trim Black 39143. Nice product.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 04-21-2014, 07:12 PM
intocarss's Avatar
Out here in SoCal I can find the semi-flat", p/n 53565 at Home Depot or Pep Boys That satin looks like S*it
Old 04-21-2014, 07:16 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
this is a very good and inexpensive single stage that dries almost instantly and looks great.http://cgi.ebay.com/ebaymotors/EXCEL...item20ce626696
Old 04-21-2014, 07:29 PM
JB64CHEVELLE's Avatar
JB64CHEVELLE JB64CHEVELLE is offline
Orchard supply brand semi gloss works great for small parts. For $3 bucks a can it works great. Try it for $3 bucks if you don't like it you didn't lose much.
1964 Chevelle SS,Ls1,T56,DSE 3 front&rear
1964 El Camino
1971 Chevelle SS
1971 Camaro
Old 04-22-2014, 05:38 AM
69hugger's Avatar
All,
Thanks for your suggestions. Funny how so many people have so many ideas on this.
ADiCarlo... I didn't think of DupliColor. I will see if they have a semi-gloss. Thanks!
65_LS1_T56.... Never tried SEM products. I don't know where to get it. I may have to do further research on this.
intocarss... Interesting that HD carries Krylon out there, but Rustoleum up here. Pep Boys doesn't carry the semi-flat at the few stores I called. I agree the satin is not great. I have a can of Krylon semi-flat coming today from Amazon. I hope it has the right sheen.
tubbed69... Thanks for that suggestion. I would have never thought of E-Bay for paint. Kinda hate to have to mail order every time I need a can or 2 of black. It takes days to get & freight usually ain't cheap.
JB64CHEVELLE... We don't have Orchard Supply up here. I wonder who private labels it for them? Usually 1 of the bigger mfrs that has their own brand(s).
Sieg....I am disappointed you are not impressed with the Krylon Semi-flat. I was hoping that was the answer. I am not one who likes to watch paint dry, so I think the X-O may drive me crazy. I am certain to stick my finger in it like an 8 year old and have to start over.
Ron in SoCal... I didn't know Sikkens comes in aerosol? If it does, maybe I can find that at an auto body supply?
Yesterday I tried Rustoleum Professional & Valspar, both from Lowes. They are not good. Translucent, very thin, and too shiny. I have many cans of black paint to donate to our local homeless graffiti artists....
Keep the suggestions coming if you have found the grail of readily available aerosols.
Thanks!!
Old 04-22-2014, 06:05 AM
Musclerodz's Avatar
duplicolor engine enamel is available in low gloss and semi gloss. I tend to use a lot of it on small parts when I am not doing a large batch in the paint booth. I also like SEM trim black but is not as readily available and even more expensive. Spray can prices have gotten stupid.
Another option would be to go to your local paint supply store and have a spray can made up of the automotive paint you want to use. Usually about twice the price of a store bought can.
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-22-2014, 06:55 AM
Sieg's Avatar
Sieg Sieg is offline
I was crushed!
I was hoping it was a bad run but I've bought multiple cans 3-4 months apart and I fear they've change formulas. I'd still try it. Just be prepared to be patient and apply multiple (5-6) very light coats a couple minutes apart and use 10-12" distance. The first coats lay down with a translucent look which the semi-flat (now satin) never did. It's much easier to get runs whereas the previous formula was 3 medium passes and walk away.
The X-O is testy but it lays down and covers nice and the durability appears to be superior. But it's definitely a shoot it and step away from the part for 8 hours paint.
Old 04-22-2014, 07:40 AM
renegade6 renegade6 is offline
I've had really good luck using the trim spray that another poster mentioned. It is about the best match for the semi-gloss under the hood.
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
