Old 12-10-2016, 09:09 PM
mjt8002 mjt8002 is offline
Default 1964 Falcon Sprint
New to Lateral G. Looking forward to checking out all these cool rides. Here's the specs on mine;
289 small block 11.5 to 1 compression
Edelbrock E-street heads
Performer Air gap manifold ported to match heads
Comp Cams billet roller rockers and High energy 274H cam
VIntage Air front runner serpentine belt system with power steering and A/C
Quickfuel 680cfm carb
Dougs long tube headers
Canton Road Race 7qt pan.
Exhaust
2 1/2" stainless X-pipe with magna flow mufflers
Fuel system
Aeromotive Stealth Mustang fuel inection fuel tank with internal fuel pump. Setup as a full return system with regulator to neck it down to carb fuel pressures.
Trans
T5 5spd w .69 OD modified with a chevy S-10 tail section to move the shifter farther forward
Quicktime scattershield
Full Kevlar clutch with Tilton Hydraulic internal slave.
Susupension
Global West coilover front suspension with tubular upper and lower control arms
Maier racing front 1 1/8" front sway bar with modified mounts to clear oil pan.
QA1 double adjustable shocks on all four corners.
Wilwood 13" front discs with 6 piston calipers
EPS custom narrowed rear leaf springs with Mini tubbed rear wheelhouses to clear a 275 rear tire
Maier racing rear Panhard Bar
Interior
Stock 1965 falcon interior with the excelption of Scat Pro Car front seats recovered to match stock interior style
Ididt tilt column with Billet Specialties Split grip wheel
Custom fabbed center guage A/C cluster.
Wheels/Tires
Team III wheels with Falken Azenis 615K tires , 235 fronts. 275 rears.
Body
Custom fabbed front/rear spoilers.
Fibergalss Hood with 2013 mustang GT hood vents
Fiberglass bumpers
Cowl vent and emblems shaved and/or modified.
With the exception of Major Body and Fender/Paint, wiring and Interior, Car was built in our garage at home.
Old 12-13-2016, 07:45 AM
GTWayne GTWayne is offline
Default T5 S10 mod
Interesting mod to move the shifter. There are a bunch of console owners that would like to see some pictures of that. Topside AND underneath. Nice work!
Old 12-13-2016, 09:53 AM
Sweet! Welcome!
Old 12-13-2016, 01:21 PM
syborg tt's Avatar
Great looking car and welcome to the site.
marty-mj
Old 12-20-2016, 07:39 AM
67XR7's Avatar
67XR7 67XR7 is offline
Matt,
Nice to see you're now on here.
I have more cougar pictures posted on my build thread here, then i've posted on IG.
If you haven't heard it enough from me, Nice rig!
1965 Chevelle, Pm me if interested in wheel tool rental
Old 12-21-2016, 09:10 AM
Nlped47's Avatar
Nlped47 Nlped47 is offline
From another Falcon owner... This car is a beauty!!! I hope mine is even close to as nice as yours one day
Old 12-21-2016, 11:02 AM
67XR7's Avatar
Bruce at Modern driveline can provide you plenty of pictures, he performed this mod on a t-5 Z that I put in my cousins 64 comet while the bench seat was still in place. I believe he now offers a casted piece to accomplish this due to lack of finding good used pieces from a Chevy S-10.
http://moderndriveline.com/Technical...ailhousing.htm
even uses a std t-5 rear shift shifter so that one would not have to source out the "square style" gm t5 shifter. not to mention the huge used market for ford t-5 shifters.
