Old 07-09-2006, 07:11 AM
Dads502 Dads502 is offline
Default Battery Drain
I have a recently restored 69 Camaro with Painless wiring, and Optima battery mounted in the trunk. It has a high output Alternator, and 1 gauge cables running from the trunk to the engine. While driving, the battery charges normal, but after shutting down the engine, there is a 4 amp draw on the battery as measured with an ampmeter on the cables. I have checked all fuses and nothing seems to be related to the current draw. It will go away after several hours of sitting, and it will also go away immediately if I disconnect the battery cable for about 10 sec. Does this sound like a bad relay, or battery?
Old 07-10-2006, 06:20 AM
XcYZ's Avatar
XcYZ XcYZ is offline
4 amps is a substantial drain.
Have you tried disconnecting your alternator?
My LS7 69 Camaro
Old 07-27-2006, 07:26 PM
morris69 morris69 is offline
I just had that same problem with my 69 it was my altenater it was a one wire and i had a two wire setup
Old 07-27-2006, 09:47 PM
907rs's Avatar
907rs 907rs is offline
Did you ever figure it out?
Bill
Old 08-02-2006, 05:58 PM
71Nova 71Nova is offline
with your battery in the trunk are you running the 1 wire alternator wire all the way back to the battery? or to the starter?
Old 08-02-2006, 06:30 PM
fatlife's Avatar
fatlife fatlife is offline
Banned
make sure you have your meter set right, a .004 amp draw can look like a 4 amp draw if you don't have it setup right. If your battery isn't going dead after sitting for awhile I would say nothing is wrong
