Old 08-09-2006, 10:23 PM
PSV's Avatar
PSV PSV is offline
Default Help, my ron davis radiator doesn't fit
I have a 69 camaro with a BB and the fan on the driver side hits the power steering pump. The radiator support still needs to come toward the engine 3/4" and already overlaps the snout of the power steering unit by 1/2 inch. The radiator is the 11-16ca69 with a 3 1/2" unit. With fans it is 9 inches wide and best I can tell I only have 7 and 1/2 inches to work with. Does anyone have any ideas to make this work? The radiator is awesome but I I can't seem to figure out a way to make it work. I have the March serpentine system for a long water pump. I know others with camaros and BBs must be using this system but how? Here is a picture that I hope shows my problem. Frank, I think I remember you using the radiator on Prodigy, is the engine set back? How did you get this system to work?
Old 08-10-2006, 05:45 AM
MaxHarvard's Avatar
is the fan from ron davis too?
Old 08-10-2006, 06:18 AM
68protouring454's Avatar
Default pump
as far as i know you really need a short water pump to use much of anything on a camaro with a big block, jody used a mark viii fan and a long water pump but needed a different radiator
jake
Old 08-10-2006, 07:22 AM
PSV's Avatar
PSV PSV is offline
Default fittment
Thanks for the replys. The entire unit is from Ron Davis. It has the dual fans and integrated overflow tank. I considered the short water pup, but I don't think the short water pump will move the power steering pump any closer to the block. Am I wrong?
Old 08-10-2006, 07:28 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I had a long wp on my '68 bbc. I used the dual spal fan set up. I had to trim about 1/2" off that shroud to make it fit, and it was still very tight. Water pump pulley had to go between the fans to work. Power steering pump wasn't an issue.
Old 08-10-2006, 07:54 AM
Matt@Lateral Dynamics Matt@Lateral Dynamics is offline
Have you called Ron Davis?
