Old 03-25-2020, 09:06 PM
flyingv's Avatar
flyingv flyingv is offline
Default LSA engine harness rework
Can you guys give me some recommendations on reworking a factory LSA harness to use in my 1960 Impala.
I'm currently stuffing an Art Morrison chassis under it and had been running a 24x 0411 ecm with a speed density tune. I'm going to swap the crank to a 58x and would like to run the E67 ecm and harness that I have out of my Road Race CTS-V
Obviously I'd like a quality harness rework with a nice sealed fuse box
Thanks for the help
Sent from my SM-G977U using Tapatalk
Old 03-26-2020, 08:23 AM
CarlC CarlC is offline
Are you looking to rework it yourself or farming it out to someone?
http:www.vaporworx.com
Old 03-26-2020, 08:27 AM
flyingv's Avatar
I'd prefer to have someone else do it.
Old 03-26-2020, 05:28 PM
dhutton dhutton is offline
Speartech does a nice job on reworks.
Old 03-27-2020, 10:04 AM
billohio billohio is offline
I am going to have speartech do mine also. Seemed real knowledgeable
Old 03-27-2020, 10:30 AM
colorado80439 colorado80439 is offline
X3 for speartech, sweet ride!!
Old 03-27-2020, 05:14 PM
flyingv's Avatar
Any pro or cons if I went with the GM Performance LSA harness instead?
I like the sealed fuse box and price wise it's comparable to a rework since I have the pedal, o2's and MAF already.
Thanks for the replies
Old 03-28-2020, 07:48 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I've used Speartech and HotWire, both excellent results.
Jeff-
Old 03-30-2020, 07:15 AM
If you decide to use the harness and ECM the fuel requirement is a bit odd. We have the fix for that when using a GM ZL1 fuel module (the best.)
https://www.vaporworx.com/product/pr...-level-sensor/
Old 04-03-2020, 10:54 AM
Back when I would pay someone to do that, there was (still is, I think) a guy I used on Ebay named something like CookMike222 in SoCal who did both the harness rework and the initial PCM re-program for my Falcon's engine. His price was very good (way better than those mentioned above, like less than 50%), as was the work he did. You just have to ship him your junk in a box, with a list of your parameters.
If you know somebody with HPTuners, you can do a basic reprogram in like 15 minutes or less. People have made careers out of this . . .
