Old 09-25-2006, 04:37 AM
tomspo04 tomspo04 is offline
Default Front is sitting WAY too high!
Help, anyone? I set my second gen Camaro on the ground and it's sitting 2-3 inches too high. Everything is new. Upper CA's are Hidts, Lower CA's are GW, springs are Hotchkis (small block). The engine is in (ZZ502, Aluminum heads) all accessories are mounted. I originally had the Hotchkis BB springs but swapped them out for the SB...it's still too high! Any suggestions?
1970 SS (L-34) Protouring Camaro, 502 RJ, TKO 600 W/aluminum drive shaft, 3.42 rear, C5 ZO6 brakes front & rear, Hotchkis TVS, Boze Mesh; (17X9.5 275-40) & (17X11 315-35), Rick SS fuel tank W/pump, March Ultra serpentine setup, Hiedts/GW UCA's & LCA's, MagnaFlo 3" SS exhaust w'Xpipe.
