Old 10-11-2006, 12:29 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Does anyone know who offers an A6 for PT Cars, or who is working on one??
To All:
I appreciate any info you can provide.
Thanks,
tyoneal
Old 10-11-2006, 10:08 AM
Diognes56's Avatar
Diognes56 Diognes56 is offline
I am sure it only a matter of time before GM's 6L80E becomes more readily available and somebody figures out the programming involved.
David
Old 10-11-2006, 01:43 PM
Steve Chryssos's Avatar
I spoke with Mark Bowler last week. Bowler Transmissions has two products that make a true auto six speed manumatic a reality using an existing four speed auto and a gear vendors overdrive:
1) Modified Valve Body: Provides full engine braking when the gear selector is in the "3" position. This product is still undergoing transmission durability testing. But you can "hear" it in action in this video.
Engine Braking Valve Body Mods
2) GV Interface Electronics: Mark has electronics that will actuate both the transmission shift solenoids AND the gear splitter from the same switching mechanism such as my paddle shifter.
This is technically an eight speed transmission when the gear selector is in the OD position. However there is no engine braking in this mode.
________________
Steve Chryssos
Ridetech.com
Old 10-11-2006, 08:18 PM
tyoneal's Avatar
Steve:
Thanks for the great information.
I'm really hoping they can put a "Bullet Proof" package together. It would be great to have the choice of having an automatic, OR a "Manual" transmission in the same car.
With the Shrifter Technology, can it be used to create an, "Inline" shifting transmission, without having to spend 20k on a Tranny? I think that is the right term, however if it isn't, I am refering to the Manual Transmission that to shift to a higher gear you pull the stick back towards you and to downshift you push the shift lever towards the front of the car.
Also, can the Shrifter be set up to use one paddle? (Pull back to shift up, pushing forward to shift down)
Thanks for you input, I'm excited to seeing what types of Transmission choices are on the horizon for our PT Cars.
If you hear anything further, please feel free to post it. I really think products like yours will be a big part of the Sports Cars of the future.
tyoneal
Old 10-12-2006, 06:45 AM
The 4L80E/Gear Vendors combination is as bulletproof a solution as you will find.
The term you are referring to is "sequential". The answer is no. You cannot effectively adapt a sequential manual transmission to your street driven hot rod without dropping big bucks.
It would be expensive and consume additional depth, but yes.
It will be many years before you see any forward progress made with regards to mechatronic manuals or the adaptation of clutch to clutch automatics. The hardware is within sight, but it's difficult to package the electronics (software and programming) into a marketable product.
________________
Steve Chryssos
Ridetech.com
Old 10-12-2006, 07:10 AM
CraigMorrison's Avatar
CraigMorrison CraigMorrison is offline
Isn't the 6L80E a gigantic trans? I know the 4L is big(Lots of customers are using this trans and have heard lots of PITA stories about mounting such a big trans.)
What about weight?
I would think the size and weight (and cost) would keep this tranny in the relm of truck/towing applications, as there are a lot of options already available for us.
Just thinkin' out loud while the coffee kicks in........
Old 10-11-2006, 08:22 PM
tyoneal's Avatar
David
David:
I hope your right. A six speed, "Manumatic", would be a blast to play with, and when you were stuck in traffic, you could engage the Automatic mode, turn on the radio, and just relax instead of having to fight with a stick.
tyoneal
