Old 11-06-2006, 08:21 AM
tomspo04 tomspo04 is offline
Default REAL hard Brake pedal...Help!
I've got stock 70 Camaro disks up front, 79 TA disks in the rear and a manual brake 68 Vette MC (1-1/8 Piston). The peadal is hard as a rock. Any suggestions? Thanks, in advance.
1970 SS (L-34) Protouring Camaro, 502 RJ, TKO 600 W/aluminum drive shaft, 3.42 rear, C5 ZO6 brakes front & rear, Hotchkis TVS, Boze Mesh; (17X9.5 275-40) & (17X11 315-35), Rick SS fuel tank W/pump, March Ultra serpentine setup, Hiedts/GW UCA's & LCA's, MagnaFlo 3" SS exhaust w'Xpipe.
Old 11-06-2006, 10:17 AM
chicane's Avatar
chicane chicane is offline
The master cylinder might be a little bit too large for the pressure to volume ratio that your brake set up requires. A change to a smaller bore would help...
Old 11-06-2006, 11:28 AM
Chicane, Any reccommendations? Thanks...
Old 11-06-2006, 01:47 PM
Silver69Camaro Silver69Camaro is offline
For a manual application, 1.125" is WAY too big. You need to be in the 0.875-1" range, assuming you have a pedal ratio of 6:1 or more.
