Old 12-17-2006, 04:19 AM
1Cool68's Avatar
1Cool68 1Cool68 is offline
Default Complete drive-train for sell!
Complete drive train for sell! Everything from all of the assesories to the drive line, even the custom crossmemeber for the 6spd trans. EEEVVVERRRRYYTTHHIINNGG!!! Going to be doing a full LS-1 and auto trans conversion to the car. I can send many pictures and even a video. Runs on pump gas and stays cool!
Parts list:
454 ci big block. Stroked to a 496ci. Stock 454 heads with 2.19/1.88 stainless steel valves
Victor JR. intake with a Mighty Demon 850 carb.
MSD 6AL box, Pro Billet distributor, Blaster 2 coil
Hooker Competition ceramic coated headers
Moroso 7qt oil pan
ATI super damper
Hays SFI flywheel
SCAT 4340 steel crank (balanced)
Eagle 4340 H beam rods (balanced
Speed Pro 11:1 pistons (balanced) w/chrome moly rings, with the large cc heads the final ratio is 10.5:1
Comp Cams 6.19, 6.19 lift hydraulic roller cam
Comp Cams hydraulic roller lifters
Comp Cams Pro Magnum rocker arms 1.7 ratio
Comp Cams Stud Girdles
Comp Cams titanium retainers
Comp Cams dual coil valve springs
Pete Jackson gear drive
Hays competition pressure plate and clutch disc
GM performance parts serpentine belt kit
GM performance parts aluminum valve covers
K&N extreme air filter kit
Holly fuel pump
All ARP fasteners
T-56 6 speed manual transmission
D&D 6 speed adapter kit
hydraulic throwout bearing
hydraulic slave cylinder
Lakewood steel bellhousing
New reverse lock out solenoid
Professionally shortened drive line
Custom built crossmember
Hurst billet plus shifter
Price: $9000
Cell: 360-600-0109
