Old 01-16-2007, 08:07 AM
va72mlibu's Avatar
va72mlibu va72mlibu is offline
Default (was) Auto-X Classification question
I'm having trouble figuring out what class my Chevelle would run in Solo II Auotcross. The rule book is confusing to me. The car is nowhere near stock, so that's adding to my confusion. Any thoughts?
Eric
'72 Malibu - The FULL RIDE, LS7 power, Optima juice
'05 Volvo S60R, (my Swedish Hot-Rod)
C-12 Huron (operated but not owned)
Fquick page
Old 01-16-2007, 11:48 AM
mazspeed's Avatar
mazspeed mazspeed is offline
It's going to depend on how unstock it is. Tires, suspension, engine all play a role, but if everything is real custom, then may just have you in open class where all the quick autox cars are. A Chevelle is not going to do well there. How modified is your car?
Old 01-16-2007, 12:05 PM
chicane's Avatar
chicane chicane is offline
Well... having said that, you'll either fall into SP (street prepared), SM (street modified), P (prepared) or M (modified).
It really depends on the actual modifiactions. What exactly has been modified ??
Definitions start on page: 167 and class clarifications on 234 (specifically 240 for your scrutiny)
http://www.scca.com/_FileLibrary/File/2007SoloRules.pdf
Old 01-16-2007, 01:24 PM
va72mlibu's Avatar
I'm thinking I'll be in SM2. Here's my specs:
Engine bay: 2006 Corvette LS7 (7.0 liter) with headers and no catalytic convertors, K&N Cone filter, Big Stuff FAST II engine software, custom modified dry sump oil tank. Aluminum radiator.
Exhaust: Magnaflow 3" dual exhaustTransmission: Rockland Gear/Tremec 6-Speed T-56 Viper transmission. Hurst Shifter.
Rear end: Currie/Ford 9", Detroit Locker Truetrack limited slip differential
Frame and suspension: stock frame rewelded, re-inforced and powdercoated. Complete Hotchkis TVS suspension with Bilstein shocks, Tubular upper and lower Control Arms, Detroit Speed and Engineering Quick Ratio steering box. All new Energy Suspension poly bushings.
Brakes: Front: Baer “6S” Monoblock 6-piston caliper w/ 14" 2-piece slotted rotors. Rear: “Baer Claw Track”, 13" slotted rotor.
Wheels and tires: 18" Bonspeed Delta, 275/35/18 front, 295/35/18 rear, Goodyear Eagle F1 tires
Interior: Sparco Racing seats with 6-point harnesses and Sparco racing steering wheel.
I really could care less about being "competitive". I just want to drive the car hard. I don't want to show up and look like a dumba** because I didn't know what class I was in.
Eric
Fquick page
Old 01-16-2007, 02:00 PM
mazspeed's Avatar
In my day they would have put you in a open class or modified class. You have street tires which will keep you out of the open class. Anything lower then a 40 treadwear rating would have been in a open class then.
Old 01-16-2007, 04:03 PM
Jr's Avatar
Jr Jr is offline
This is the Chevelle that won the optima batteries full ride contest. Scott has pictures from sema posted on the home page
Old 01-17-2007, 02:08 AM
71Nova 71Nova is offline
Whats going on Eric. Cool to see my Apache Bro back to Lat-g. I remember a long time ago before you won the optima competition you mentioned that we might know some of the same people. We lost a couple of longbows and pilots over in Iraq and was wondering if you knew them. They were good guys, I have a lot of respect for them. Especialy Mr Mariotti. I had many conversations about flight theory with him. He flew Augusta's for an oil company before joing the Army.
David
