Old 01-10-2007, 05:45 AM
makoshark makoshark is offline
Default 67 camaro parts, LS1 parts and SBC parts. Most are New!
All items are brand new in the box unless noted
CC- 611-16. 10 degree valves locks
CC- 503-16. Teflon valve seals
CC- 730-16. Titanium retainers
CC- 3136. Double roller timing chain
All those parts are brand new, still in the box.
I`ll sell them for $175 shipped
67 SS350 Emblem kit from Rick`s....$100
67 SS350 Gas cap from Rick`s....$35
67 SS350 Horn button....$20
67 Auto shifter(PG) with new button and spring.....$185.
OD conversion for 67 auto shifter and console indicator plate.....$50.
CP-127 67 FLOOR SHIFTER FLEXI-ROD ACTUATOR....$40.
TH350 Stainless steel hard cooler lines....$65
67 Z28 stainless stell fuel pump to carb hard lines....$45
69 camaro stainless steel front disc brake hard lines....$70.
69 camaro stainless braided flex hoses for front discs....$40.
1990 TH700R4 in good condition (used) with truck convertor....$250
67 GM original in excellent shape auto console shift plate....$45.
4) 15x7 GM ralley wheels with 4.5" backspacing fully restored with brand new trim and new 67 center caps and brand new BFG 255/60 and 235/60 tires....$725 (available soon)
JE Forged 383, .030 overbore, 6." rod pistons (Brand New)....$200
Eagle SIR I-beam 6" rods (Brand New)....$200
67 camaro repro fuel tank and sender unit....$135 (available soon)
Jegs 6 3/4 internally balanced harmonic balancer....$165
Jegs ProStarter...$125.
Jegs SFI approved 168T flexplate....$40.
Edelbrock 2 piece aluminum timing cover and chrome timing tab with ARP bolts....$65
Melling Z28 oil pump....$20
CC double roller timing chain....$20.
Stock LS1 flywheel (used, but good)....$50 shipped
99 Chevy truck 8.625 rearend, with Richmond 3.73 gears, Truetrac posi, complete with brakes, lines and parking brake cables (posi and gears ran 500 miles)....$750
Summit cast 383 crank with fresh 10/10 turn, needs repolishing from sitting around...$75
317 complete truck heads....$250.
99 bare 853 heads (no notch)...$75.
99 truck throttle body....$75.
01 T/A throttle body....$75.
LS1 intake....$50.
My zip is 38611 and I don`t have paypal at this time. Will accept personal checks, but will hold items for 10 business days or cashiers check/USPS money order and parts will be shipped immediately.
Old 01-10-2007, 05:58 PM
NvrDun71 NvrDun71 is offline
What shape are the 317's in? How much mileage, Etc.....
71' Nova - LY6, T56
Old 01-10-2007, 10:23 PM
Excellent shape. They were pulled from an 05 truck with 5000 miles on the clock. They may already be sold. I`ll keep you posted on them.
