Old 10-30-2007, 02:33 AM
t/a-speed t/a-speed is offline
Default Swapping to EFI without switching cams
I'm having a hard time putting something together that will work with the below cam. I've searched several sites but can't get a clear answer as to how flexible each system will be for cam tuning.
My Options:
Stealthram with stock TPI ECM and wiring harness.
Full stealthram package from Summit.
Edelbrock pro-flo EFI.
Holley 950 system.
F.I.R.S.T. system (but was told the cam was too big for the ECM).
I want reliability and still have the performance from my 69 camaro.
It has a 355 with a 4 speed muncie and 410 gears.
Edelbrock RPM Heads, cam(234/244 @.50 .488/.510 on a 112), and Intake.
If I can get something put together then I can think about adding a six speed.
I'm not racing it, I just want to be able to start it, drive it and be able to drive it 400 miles without something going wrong.
Thanks for looking..
Old 11-02-2007, 09:50 PM
I think you have some mis-printed numbers on the duration, but I think I know which one you're talking about. That is not a large cam and should not cause any issues with a system that can be tuned. If the FIRST system can't tune that then it is either not tuneable or severely limited and should be avoided.
Old 11-03-2007, 07:56 AM
Your so right about the specs, I edited the post to reflect what I think are the right numbers.
I emailed the FIRST people and they use a 730 ecm but the highest duration their people will tune for is 220. I can go my own route and either have it tuned or try it myself.
Since the car is show with some go, I think I can get away with having someone else burn a prom. There seem to be some good companies out there for this.
Old 11-03-2007, 09:00 AM
I would avoid any efi system that cannot tune beyond a 220 @.050 duration cam. Basically they are saying we're using a stock computer (which is fine) but have no way to tune it. The advantage of efi is in the ability to tune it; any of the other systems you mentioned could tune that combo easily, as well as FAST, BigStuff3, Accel, or simply a stock GM computer and tuning program like HP Tuners or EFI Live.
Old 11-03-2007, 11:55 AM
Thanks for the reply,
I was under the impression that the 730 ecm was a GM unit.
Meaning, I could have a custom prom made or buy my own equipment to burn proms.
Old 11-03-2007, 01:51 PM
nothing wrong with it if it's tuneable. I started in EFI with a prom-burner and tuning software. I do prefer the systems that tune via a laptop and allow faster changes vs the burning prom deal, but they both work.
