Old 01-06-2008, 10:54 PM
blown71nova blown71nova is offline
Default FS: Comp Cams Drag Race Solid Roller Camshaft--Almost New
Cam Has Only 5 Dyno Pulls on It
Small Block Chevy V8, 262-400, 1955-1998
DRAG RACE Mechanical Roller Camshaft
5,000 Stall / 11:1 Compression
A cam designed for nothing but racing.
If you're looking for more than just a streetable cam, COMP Cams has designed a drag race cam for you. These cams are designed specifically for all-out drag strip performance.
Summit Racing Part Number# CCA-12-906-9
Cam Style: Mechanical roller tappet
Basic Operating RPM Range: 4,500-7,500
Intake Duration at 050 inch Lift: 276
Exhaust Duration at 050 inch Lift: 284
Duration at 050 inch Lift: 276 int./284 exh.
Advertised Intake Duration: 312
Advertised Exhaust Duration: 322
Advertised Duration: 312 int./322 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.630 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.630 in.
Valve Lift with Factory Rocker Arm Ratio: 0.630 int./0.630 exh. lift
Lobe Separation (degrees): 107
Intake Valve Lash: 0.020 in.
Exhaust Valve Lash: 0.022 in.
Computer Controlled Compatible: No
Grind Number: CS 312A-R7
Notes: Requires upgraded gear, thrust button, and wear plate.
Cost Me $330 Shipped New from Summit Racing
My Loss Is Your Gain
$175 Shipped
Old 01-11-2008, 04:04 AM
Sold!!!!!!
