Old 07-08-2005, 11:42 AM
Musclerodz's Avatar
Default Look at what I scored today. 3-link rear end!
Well, I was out with a friend yesterday treasure hunting at the local salvage yards. I saw a pile of 9" rears and found this one. Factory 3 link, disc brakes, and has these cool vented backing plates. The best part, $175.
It says removed from 76 Lincoln but I don't beleive it. It has a speed sensor on the yoke which I think is ABS or cruise. Either way, I could not pass up for the Camaro. It will be way easier to install than the 12 bolt I was going to use.
I won't be using the offset link. I will be using a center link so I can retain back seats. Now to get this thing stripped and mounted under the car!
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 07-08-2005, 12:29 PM
phonedude_mln phonedude_mln is offline
Mike
make sure you did not pick up a 9 3/8" rear, see ~ mid way through:
http://www.kevinstang.com/Ninecase.htm
conventional wisdom is that the 9 3/8 is not as strong as the 9". but the center sections
are swappable, and you have 31 spline axles. but probably a 2.50:1 or 2.75:1 ratio.
some more info re: 9 3/8":
http://www.racecheep.com/Rear%20Tags.html
also see this article about taking the rear out of a 76 lincoln:
http://www.fordmuscle.com/archives/2...cs/index.shtml
Old 07-08-2005, 01:14 PM
Musclerodz's Avatar
Great info. Especially the first site. It is a standard 9" small bearing, but I will be converting to big bearing ends. I am still looking for a later id chart to decifer the tag.
Mike
Mike Redpath
facebook page
Old 07-08-2005, 01:55 PM
TravisB TravisB is offline
So mike about that 12 bolt?????????????????????????
Interested in selling?
How wide is it?
Kenny Davis Hot Rods
Old 07-08-2005, 02:25 PM
Musclerodz's Avatar
How wide is it?
12 bolt is a housing only for a Chevelle. $100 if you want it.
Mike
Mike Redpath
facebook page
Old 07-08-2005, 07:16 PM
race-rodz race-rodz is offline
make sure its not 5 on 5 bolt patern
