Old 12-10-2004, 07:18 AM
Jerebus67 Jerebus67 is offline
Default 67 Convertible suspension ?
I would really like to beef up the suspension on my 67 Convertible that I just purhcased. It is totally stock and Hotchkis said that their TVS package is not guarenteed to work with a Convertible. The said that their rear might drop more than the 1.5 inches with the extra weight of the convertible. I love the pro touring stance. Anyone have any suggestions on what to purchase?
Old 12-10-2004, 08:39 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I guess I've never heard that before, but then again, I've never worked with a Vert. Maybe Trush will give his opinion as he's the only one here with one.
My LS7 69 Camaro
Old 12-10-2004, 09:17 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Default It will work...
I have the Hotchkis system in my Convert, and had no issues whatsoever. They are very well engineered components, and are designed to work together very well. The car sits exactly where I wanted it for "the look", with no modifications to the components as supplied by Hotchkis. I would check Summit for pricing, as I believe they are the best price out there.
You can see more pics of the stance here:https://lateral-g.net/trush/
Good Luck
Here are some reference pics of ride height w/18 inch wheels.
Old 12-10-2004, 09:40 AM
That is one sweet ride. Can you tell me everything you did to yours in order to get 18's on that 69? That is exactly how I want mine to sit.
Old 12-10-2004, 10:16 AM
Lateral-g Moderator
Default Easy....
I really didn't do anything except research....I have 18X8 on the front with a 4.74" BS, and a 235/40 and the rear is a 18X9 with a 255/45 with 5.5" BS. They fit fine with no rubbing whatsoever. It is possible to fit a 9.5" rim in the rear, with a 275/40 out back, the only issue I have with that is the "gap" between the top of the rear tire, and the quarter due to the lower aspect ratio of the 40 series, If the car is not low enough, it can look like the car is raked "backwards" from the side, but that is purely my opinion. I wanted my tire tucked up in the rear quarter, so I sacrificed some contact patch, in going with the 255, but the 45 series fills that gap nicely....Be sure to measure measure measure to ensure the rim sizes you pick will fit. Remember, once you mount them you bought them for good. The sizes I chose are a pretty safe bet on most first gens. If I did anything different, I may have chosen a 245/40 for the front, but the nice thing in the choice of tires, is that the rear 45 series, and the front 40 series, give you a natural 1-2" forward rake to the car, due to the tire height differences, even while maintaining the same rim diameter.
Here is what I mean:
Here are a couple of shots to show you depth etc....Don't mind the hokey fake disc covers, this was before the Baers were on...
Good Luck, and let me know if you have any questions.
Welcome to the site.
J.T.
Old 12-10-2004, 10:42 AM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Jerebus67
I am also build ing a Convertible and decided to go with the Martz Chassis adjustable 4 link with Coil Overs. You can adjust the ride as you see fit (obviously with some limitations).
Look here:
http://www.martzchassis.net/page7.htm
Good Luck and welcome. If you are building a Protouring car, this is your lucky day, man, you've found the right place and the best guys on the net to help you. No Egos here.
Jim
