Old 03-18-2008, 12:21 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Anybody ever Turbo Charged a Nailhead?
To All:
I have an extra 425 Buick Nailhead, for another project and since their valves are so small, I looking at other ways to help them make good power.
Has anyone every done a Turbo on one, or know of some one that has a universal kit if some kind?
Maybe ProCharger?
Thanks,
Ty
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
Old 03-18-2008, 04:55 AM
fesler's Avatar
fesler fesler is offline
We have done a few Nailheads but they have all been supercharged, the problem is no one makes parts for them so they are very hard to build, everything has to be custom built. It is going to cost you a fortune to build this engine to run a charger or turbo and if you need some info on where we got some of the stuff I can dig it up for you. They are great engines but no one really makes much for them. Here are some pics of the 1949 Merc we built a few years back
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 03-18-2008, 06:45 AM
Blown353 Blown353 is offline
That Merc is BAD.
1969 Chevelle
Old 03-18-2008, 09:41 AM
V8TV's Avatar
V8TV V8TV is offline
There's a Hot Rod story from the early '60s with a turbo nailhead on the cover, but it was all GM internal stuff. Would be cool to see someone do one now!
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
Old 03-18-2008, 07:11 PM
Rellim51 Rellim51 is offline
Not turbocharged but it is pretty strong. The carbs are actually throttle bodies with 2 injectors hidden in each one. It's controlled by a FAST XFI computer.
Old 03-19-2008, 02:03 AM
tyoneal's Avatar
That's a great looking engine. Looks like the intake might be from EELCO. They have some pretty trick parts, but NOBODY make any Aluminum Head at ALL!
It's strange to me that Edelbrock would make heads for the 409 that they made 2 years. (I believe there was 50,000 or so, and not build heads for the Nailhead.
MagnaCharger even builds Superchargers for the Ford Flathead!
Oh well, if anyone hears anything, please give me a shout.
Thanks,
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 03-19-2008, 01:57 AM
tyoneal's Avatar
I agree with you. I've found a 425 engine and tranny to build so I can save the numbers matching pieces, but the aftermarket speed parts are just few and far between.
Watching the numbers on the forums however, it looks like they are becoming more popular again. The forums are busy and the 425 engine non running but not junk will run $500-$800, and that's without anything special about them. In addition between 1953 and 1966 they made millions of them.
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 03-19-2008, 01:59 AM
tyoneal's Avatar
That would be really nice to read. If you ever run across it ..........
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 03-19-2008, 01:52 AM
tyoneal's Avatar
Your Merc is Awesome. Thanks for the pictures. I was thinking a Turbo might be easier because you wouldn't need to mess with a special intake. Maybe something like a STS system. I know a lot of people don't like them, but for a older less supported engine like the Nailhead, it might be an easy was to make some good HP. Stock the 425 made 360 hp and 465 ft pounds of Torque @ 2800 rpm.
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
Old 03-19-2008, 04:53 AM
fesler's Avatar
The biggest proglem we ran into when doing this build is everyone tells us the nailhead is not a good engine to sup up, everything on it is build wrong for making high HP. We had to have everything on this engine hand build by some of the companies because no one makes anything. It will cost you some big $$$ to make the engine hold the compression you want to give it. It will be sick but might not be worth the money. Good luck
Chris Fesler
