Old 05-01-2008, 11:48 AM
olskooljr olskooljr is offline
Default 67 Camaro Wheel/Wilwood fitments
I know this is an old question, but I just bought a set of Billet Specialties wheels with 17x8 in the front and 18x9.5 in the rear. I also have a wilwood disc brake kit i will be putting on the front. Everything else is stock. This should fit ok....right?
Old 05-01-2008, 03:25 PM
slyck68 slyck68 is offline
Assuming the brakes are the 4 piston calipers I can assure you the 17's will clear them. I've never tried the 6 piston calipers so I can't say firsthand that they will fit, but they should. As for the wheel widths, 9 1/2 will be very close, but will fit most suspensions PROVIDED YOU WERE ACCURATE IN YOUR BACKSPACING MEASUREMENTS!! Good luck and I hope this helps.
Old 05-01-2008, 06:47 PM
oh, i forgot to mention the backspacing for the 17x8s is 4.5' and the 18x9.5 is 5.5'. how does that sound?
Old 05-01-2008, 07:03 PM
awr68's Avatar
awr68 awr68 is offline
The rears will be fine with a stock width axle. I prefer 4.75"-5" bs on 8" wheels on the front, your 4.5" bs should work if you don't lower the car too much.
Tony
'68 Camaro
Old 05-01-2008, 07:12 PM
Oh that information is great! I did want to lower it all around though. About how many inches do you think I could get away with in the front?
Old 05-01-2008, 08:25 PM
class67's Avatar
class67 class67 is offline
Just to give an idea...here are the Wilwood discs with 4 piston calipers all around and 18x8 (5" bs) and 18x9.5 (5.75 bs). as far as lowering, get it all together, look at it and decide then, but use lowering springs in the front instead of dropped spindles.
Steve
67 Camaro RS
66 Chevelle (in progress)
