Old 06-05-2008, 11:12 AM
monza's Avatar
monza monza is offline
Default Headers/Heat VS. Wiring ?
Any 'new or innovative' heat insulators/materials or tips or tricks for insulating wires (spark plug, sensors, starter, etc.) that run real close to headers and extreme heat areas.
Currently using a insulated foil type wrap secured with zip ties. Works ok, hard to keep 'pristine' looking, and I loose the odd zip tie from heat. Recently melted the fusible link connector (not the link~the connector) from the starter. It became a hot blob and an interesting electrical problem to trace hidden from view.
Anything better out there? Was thinking a silicone sleeve tube that would snap over wires would work great. (Like those silicone gloves you can grab hot steal with.... but in tube form?) Damn hard to wrap zip tie and get at some wires and keep them out of heats way!
So lets hear tips trick ideas or innovative materials. How do you guys keep those wires hidden, clean, in position and not molten...
Thanks!
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
62 Corvair Greenbrier
http://www.sourceboards.com/
Old 06-05-2008, 12:05 PM
I am using the MSD plug wire insulation on my starter wiring and multiple other places. I am also using the foil type other places but using stainless wire straps that won't fail under high heat. Should be some photos in my thread.
Old 06-05-2008, 02:08 PM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
Ceramic coating of the headers help some too.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 06-05-2008, 02:43 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
These work ok;
http://store.summitracing.com/partde...5&autoview=sku
Might try safety wire instead of zip ties.
Old 06-05-2008, 04:19 PM
monza's Avatar
Guess I was hoping for some thing different and techie, but I'll replace my plastic zips ties, a bit of a no brainer there?
Dave
FUeL 69 Camaro RS
68 Corvair coupe
65 Impala SS
65 Corvair convert
64 Corvair Rampside
Old 06-05-2008, 05:13 PM
J2SpeedandCustom J2SpeedandCustom is offline
Dave we have used this before it works great! On the bottom of the page the "Ultra High temp Fiberglass sleeving" good to 1200 degrees.
http://order.waytekwire.com/IMAGES/M...og/220_121.PDF
Jeff Allen
J2 Speed and Custom
Old 06-05-2008, 06:36 PM
cheezer cheezer is offline
If you just need heat resistant ties, you can get these almost anywhere.
http://www.designengineering.com/pro...sp?m=sp&pid=12
Satinless steel lock ties.
cheezer
