Old 08-19-2008, 01:52 PM
tvanderbie tvanderbie is offline
Default Wider Front wheels on a 69 Camaro
Hello, I'm new to this site. Looks like a ton of good info here. I'm building a 69 Camaro, have DSE tubs, sub frame connectors and upper and lower A- Arms. Stock subframe. Air ride on all four corners.
I'm wondering if I can go to a 9" wide wheel in the front. I could "C" out the subframe where the tire will rub. Has anyone tried a wider rim than 8" in a situation like this?
Old 08-19-2008, 05:25 PM
J2SpeedandCustom J2SpeedandCustom is offline
Subframe won't be your problem. If you want to run it low then the outside fender lip will be the problem. I would run a 8" and a 245 size tire that's all you'll need!
At Columbus this year a 69 Camaro competing for Street Machine of the year set the fastest time with a 225 size front tire and a 325 size rear tire.
Jeff Allen
J2 Speed and Custom
Old 08-20-2008, 05:32 AM
fesler's Avatar
fesler fesler is offline
We run 275 front and 345 rear on the Carmaros we build. A little C is all it needs to clear and when you are at driving hieght it clears fender with no problems. You can run a small tire but the large tire looks much better.
Chris Fesler
Fesler Built - Scottsdale, AZ
