Old 09-20-2008, 08:08 PM
vannatta20 vannatta20 is offline
Default LS1 brake mounts question
http://www.pozziracing.com/12_corvet...es_on_fgen.htm
At the bottom of the page is the template for the front brakes. I was wondering what the thickness of the bracket should be? Anyone know? Thanks!
Old 09-21-2008, 08:26 AM
fabricatordave fabricatordave is offline
it is .25 inch thick. that template is for 13 inch rotors. you need to move caliper holes in about half inch to use with camaro ls1 rotors
Old 09-21-2008, 08:23 PM
I thought the template on the right is for the 12 inch rotors? Is that correct?
Old 09-23-2008, 02:04 AM
I had a buddy of mine CNC a set for me. I am holding out drilling the holes until I can get to the car and test fit them.
Old 09-27-2008, 12:58 PM
Joey316G Joey316G is offline
are those brackets for C5 calipers and rotors?
Old 09-30-2008, 10:33 PM
13 inch
Old 10-03-2008, 04:00 PM
Rhino Rhino is offline
Originally Posted by fabricatordave View Post
13 inch
Can you please explain why you think this? If you know something not listed on the page, fill us in. This is the text found directly next to the pictures...
Left is Rich Downing's template. I have been told the 12" and 13" brackets are the same with different "baskets" being the only difference, but it's unconfirmed because I have none of these parts. -David
Right is Brian's finished 12" bracket, the 6" marks are just for size, do not indicate the hole spacing. Increase or decrease rint out scale till the 6" actually measures 6" on your printout.
Old 10-07-2008, 05:20 PM
Hammered's Avatar
Hammered Hammered is offline
13" I tried using that info for my own LS1 brake conversion and had to move the holes. In the end, I took my own measurements and designed my own bracket.
1967 Firebird Convertible, 462, EFI, TKO
My Firebird
