Old 12-27-2008, 02:37 PM
camaro2nv's Avatar
camaro2nv camaro2nv is offline
Default Shaved firewall
So today I cleaned up my firewall and cut out a new fill plate. Im a bit stuck at this point. Im really trying to make it smoooooth. But I dont know if I should save the trim tag or not! Thoughts??
Old 12-27-2008, 03:15 PM
thedude327 thedude327 is offline
There are factory syle rivot kits available if you want to reattach it later. Which is an option.
Paul
Here's a link to one seller of them on ebaymotors...........
http://cgi.ebay.com/ebaymotors/CAMAR...1%7C240%3A1318
1973 Z28 Street-touring project.........
Old 12-30-2008, 07:07 PM
camaro2nv's Avatar
Thanks, I didnt know they made that tool. Ill leave it off for now then. Thanks a lot!
Old 12-30-2008, 07:50 PM
almcbri's Avatar
almcbri almcbri is offline
I personally like them off, but for some reason I already drilled my holes when I was fabbing up my firewall! It looks cleaner without IMHO.
Nice Work on the firewall
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 12-30-2008, 08:42 PM
Steve1968LS2's Avatar
I leave them off.. keep them in an envelope with the car's paperwork.
The smoother the look the better in my opinion..
Old 12-30-2008, 08:44 PM
Oh, If I were you I would block off the two access holes to the the cage nuts for the subframe. So long as they are in good condition you should never need access and they look much better sealed up.
If you don't seal them up its really hard to make that area look good.
There will be a story on this in an upcomming issue of Camaro Performers.
