Old 01-01-2009, 07:58 PM
JohnC JohnC is offline
Default Why are these weld marks/holes on the side of my Ron Davis radiator?
Just wondering if anyone here knew the answer since ron davis is closed until the 5th. (Part Number 11-37BA7073) There are two on each side about the size of a dime...
John
Old 01-01-2009, 08:47 PM
bentfab's Avatar
bentfab bentfab is offline
Hey John,
My guess would be a roset weld to hold something on the inside that they can't weld or position until it goes together. Or it's just the way they assemble that particular radiator.
Mark
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 01-03-2009, 07:21 AM
Thanks, Mark.
I guess all 190 views agree with you otherwise I'm hoping someone else would have chimed in?
John
Old 01-03-2009, 07:35 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I don't know what those are for. My RD radiator is built a bit different and the mounting brackets cover that area of the tanks up.
Are you running an auto trans?
My LS7 69 Camaro
Old 01-03-2009, 07:57 AM
No, 6-speed manual.
Old 01-03-2009, 08:05 AM
Just looks like reinforcement for your mounting brackets that also support your fans.
Old 01-03-2009, 07:36 AM
thedugan's Avatar
thedugan thedugan is online now
For the price of that thing I would not expect to see that.
Looks like bad quality to me.
My Northern does not have that.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 01-03-2009, 09:30 AM
deuce_454's Avatar
i take it you havent actually seen a ron davis radiator... the quality of these things is unrivaled (i have 2 and compared to my past ones, be-cool, afco and griffin its just plain a different league) just look at thw welds at the end of the tanks... they even cut the aluminum so the bends they put in later will be perpendicular to the grain in the material to avoid cracks, twice as much production waste, but a better product...
my bet is that the welds are there to support, it would seem that the plate that has the two roset welds in it in the picture is sanwiched on to the element to add extra strength (it is the part that mounts the rad. to the coresupport) instead of just hanging the radiator by tabs welded onto the element.. and having to mount the fanshroud dirrectly on the element.. and since its only welded in the ends where the element meets the tank.. the two welds are most likely there to keep it tight to the element ...
Jake: Hit it.
Old 01-03-2009, 09:44 AM
Wow. Thanks. I didn't mean to start an arguement or anything. It was just a case where the curiousity got the cat. You guys are so knowledgeable and they are closed until the 5th and I received it over a week ago and couldn't wait to ask some really knowledgeable guys--like all of you! So thanks for the input.
John
