Originally Posted by David Pozzi
I have been told Flowmasters don't quiet enough at Laguna. Our 73 Camaro has a 3" X pipe then just before the mufflers we put flowmaster reducer cones from 3" to 2.5" then into the Walker 2.5" mufflers, then flowmaster mandril bent tail pipes. Even then, the car has gone over depending on conditions, so I made up some elbows for the tail pipes to divert sound to the left. We also run a 1970 Z/28 air cleaner instead of the usual open element one. It costs 10 RWHP though.
The car sounds very quiet on the track, like a stocker almost. I think the Laguna DB limit is BELOW what the state of California requires.
great info as usual from you...
I saw this info and was not amused.
Quietest performance mufflers:
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
I'm thinking about just having an extra set thrown on to see how quiet I can get it.
Damn laguna's neighbors
