Old 03-28-2009, 06:10 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default type 2 pump convert to AN fitting?
I have a type 2 pump that came with my March pulley set up, Is it possible to convert this to a AN fitting on the return side? Or can I twist the pipe with out making it leak?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 03-28-2009, 06:16 PM
68protouring454's Avatar
you need to make it press in, get the a.n fitting and turn it down so its a press fit, apply some loc tight and press in, good to go
Jake's Rod Shop
Old 03-28-2009, 07:00 PM
bigtyme1's Avatar
Is that going ot require a Lathe? what size fitting?
69 RS Ragtop
[email protected]
Old 03-28-2009, 08:05 PM
usually a # 8 or 10, get a an to pipe, then turn down threads smooth, to press fit, some loc tite and press in. remove existing tube and mic the opening, then see what size npt is just larger then it, so it can be turned down to work, #10 is most common
those pumps are 87 sunbird pumps that come with the march set ups.
Jake's Rod Shop
Old 03-28-2009, 08:13 PM
bigtyme1's Avatar
Thanks Jake, do I need to do anything special to remove the tube? or just yank it out,
69 RS Ragtop
[email protected]
Old 03-28-2009, 08:31 PM
Musclerodz's Avatar
just twist and yank.
Mike Redpath
Musclerodz & Customz
facebook page
