Old 04-10-2009, 07:38 AM
67ragtp 67ragtp is offline
Default Identify the gook
Im curious what GM is using on these header bolts removed from a crate ls7, its yellowish towards the top and cured white. If anyone knows the product name give a shout- Thanks Rich
Old 04-10-2009, 08:38 AM
DRJDVM's '69's Avatar
Its probably just some antiseize compound....alot of antiseize is silver, but with the heat, I wouldnt be supprised if it discolored to look like that
Old 04-10-2009, 09:02 AM
deuce_454's Avatar
isnt it the same thread locker thats on the dampener bolt.... its allready on the bolt in dried form when you unpack it from the GM wrapper...
as for antiseize.. be suer its compatible with alloy heads fi you decide to put it on.. i like the graphite/moly stuff from mercedes myself....
Jake: Hit it.
Old 04-10-2009, 09:13 AM
I dont think its antiseze since it seems to have dried hard and flaky like a thread locker, but not sure. Its amazing how many gook products gm is using from the Henkel corperation, I dont think they use lock washers anymore.
As for the damper/crank bolt I just ordered two of them since they are TTY and right out of the bag they were dry, nothing on the threads.
Rich
Old 04-10-2009, 10:48 AM
deuce_454's Avatar
Rich
really... i just installed a tty dampener bolt in my 02 ls1 and it had a drop of goo on the threads... dry thread locker like which is why i suggested it...
Jake: Hit it.
Old 04-10-2009, 01:24 PM
cencal69 cencal69 is offline
I'm glad this doesn't have to do with race. Whew!
