Old 06-09-2009, 08:22 PM
nonova0074 nonova0074 is offline
Default DSE Backspacing
He guys what backspacing works with the DSE Mini tub Kit? I want to run a 315/35/17 out back on either a 17x10 or 17x11. Up front I am going to run a 245/45/17 on a 17x8 should I run 5 or 4.5 bs? This is going to be on a 74 gto aka nova/ventura style.
Rob
1974 GTO 400/m21
Getting ready to build her!!
Old 06-09-2009, 09:04 PM
If your going to run a full width rear, a 7" backspace on the 11" wheel should be perfect.
Frank Serafine
Old 06-10-2009, 02:04 AM
Yup I want to keep a full lenght rear. I just am curiours 5 inch bs on the front should be ok on a 8 inch wheel.
1974 GTO 400/m21
Old 06-10-2009, 03:02 AM
5" would be fine on the front.
Frank Serafine
Old 06-10-2009, 04:38 AM
LS1NOVA LS1NOVA is offline
Im running 17x8 on the front with 5 1/4 BS. Its pretty close to my extended tie rod ends, so 5 1/8 would be perfect. You will want close to 5 to get the outside of the tire away from the fender while turning. Running SC&C uppers, extra tall upper ball joint, stock spindles, and 98-02 Camaro LS1 brakes.
On the rear I have 17x11 with 7 3/4 BS with a stock width 12 bolt and disc brakes. Fits perfect with room to tuck the tires and have plenty of room on the backside too. 7" BS would rub the inner fender well on my particular car.
Setup is Caltrac split mono's with S-10 11" discs.
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 06-10-2009, 04:13 PM
Awsome just who I was looking for a nova guy, so I have to do a 7.75 bs cause it will rub, I will be trimming the wheel wells ao i might gain a 1/2 inch of clearance. I want to order my rims soon so in 12 weeks I can have them
1974 GTO 400/m21
