Old 06-12-2009, 08:51 AM
postino postino is offline
Default Powdercoat & undercoating
Hey folks,
Question on the front inner fenderwells for my Chevelle.
So my front inner fenderwells are powder coated black. I am wondering if I can or should consider using rubberized undercoating on the under side to reduce road/tire noise, etc.?
If so, how much prep work should I do to the powder coating before spraying the undercoat? Can I just sand/scuff it down a bit or do I need to remove the powder coat completely?
Thanks in advance for your help!
Old 06-12-2009, 10:08 AM
nonova0074 nonova0074 is offline
Use a red scotch bite pad and use truck bed liner, that stuff works awsome and applys neater than undercoating. You can even get the liner in a spray can.
1974 GTO 400/m21
Getting ready to build her!!
Old 06-12-2009, 12:13 PM
OK. Great idea. Thanks for the reply.
Old 06-15-2009, 03:09 PM
paulk68 paulk68 is offline
Do you have a source for this? i have been looking for something in a spray can
Old 06-15-2009, 07:09 PM
elitecustombody's Avatar
yep, red scotch pad and truck bed coating from Duplicolor should do the job,
http://www.duplicolor.com/products/truckbed.html
just about every parts store and Wal-Mart has it both aerosol & gallon,quart cans, I use it all the time for touching up wheelwells,frames and bottom of fiberglass body kits, very easy to use, dries fast ,easy clean up and once dry,pretty nice finish,obviously it's nowhere near as durable as spray-on truck bedliner, but it's much better than asphalt & kerosene mixed junk some companies try to push as undercoating that will dry up ,fall off or get hosed off
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 06-15-2009, 07:21 PM
http://www.autobodytoolmart.com/dupl...0-p-12727.aspx
1974 GTO 400/m21
Old 06-15-2009, 07:40 PM
I remember paying $6.99 a can
