Old 08-09-2009, 10:53 AM
65 347's Avatar
65 347 65 347 is offline
Default Trunk mount battery questions
Hi guys,
I was hoping someone could help with some questions.
I want to mount the battery in the trunk,
1) what is the best mount to secure the battery
2) best place to run the cable to the front (inside the interior or out)
3) what cable should I use
Old 08-10-2009, 10:51 PM
asifnyc's Avatar
asifnyc asifnyc is offline
don't know if it'll help but I posted a blog entry about my trunk mount battery. I bought a cheap ($17) batter tray from speedway motors. bolted it to my trunk floor. ran the neg. cable right through the trunk floor and bolted to frame rail. routed the pos. cable through the trunk and under the rear seat, drilled a hole to pass it beneath the car and ran it the rest of the way to the engine bay...
http://asifnyc.com/?p=375
-asifnyc- penngrove, ca (SF bay area) asifnyc.com - Javelin Blog
1974 AMC Javelin NASA American Iron road race car
1974 AMC Matador road race project
1975 AMC Gremlin shell
1973 AMC Javelin/AMX - street
1975 AMC Gremlin - street
1970 AMC Javelin shell
1962 Rambler American vert
Old 08-11-2009, 10:45 AM
AJSZR2326 AJSZR2326 is offline
i used a #2 welding cable from battery to starter, just make sure your block has a good ground to frame
68ss 350 sbc clone ,69 LSX454ho , 70 rs 454bbc f/i
Old 08-13-2009, 04:53 PM
65 347's Avatar
thanks for your help
Old 08-14-2009, 06:42 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I ran 2 grounds. One goes right to the body, the other goes to the block. It's on the overkill side, but it's nice to know that a few extra dollars invested here won't cause potential issues down the road.
My LS7 69 Camaro
Old 08-14-2009, 07:12 AM
Norm Peterson's Avatar
Norm Peterson Norm Peterson is offline
I would weld a stud or short hex-head bolt to the chassis rather than trust a bolted-only connection not to oxidize/corrode between the bolt/stud and the sheetmetal.
On the avatar car (full-frame) I ran a short length of threaded rod through the floor (with nuts and star washers) and welded a short hex-head bolt to the frame rail. Ran one short cable from battery- to threaded rod and another short cable from the outside of the sheetmetal to the bolt. Welded another bolt to the frame rail in the engine compartment. No starting problems, ever.
It's only 'overkill' until doing it in a less fussy way doesn't let you start the car.
Norm
