Old 01-05-2005, 01:22 PM
Y-TRY Y-TRY is offline
Exclamation Introducing: The 'Y-TRY' Twin Turbo Camaro
This long-term project is finally coming to fruition after 7 years of work and planning. Here's some specs:
Engine: MoTown block 406
Crank: Scat 4340 Ultralight Stroker (2.45" mians, 3.75" stroke)
Rods: Eagle 4340 H-Beam, 6"
Pistons: JE Inverted Dome (8.1:1)
Cam: Custom Ground Solid Roller
Heads: (Well) Ported AFR 220's
Intake: GM Bowtie
Induction: Twin PT-52 turbos, Kook's Stainless headers (thanks CamcoJB), Two HKS Standard Wastegates, HKS Super Sequential BOV, TurboXS Dual Stage Boost Controller, CarbShop prepped 750hp Blow-through
Transmission: TremecTKO, Centerforce DF Clutch, Hays billet flywheel
Driveshaft: Denny's Nitrous-Ready, Mark Williams billet steel yokes
Rear: Ford 9", Auburn Limited Slip, Richmond 3.89's
Wheels: Boyd Turbo-Tech, Front: 17x7 w/ 235/45's, Rear: 17x9.5 w/ 285/40's (FM/5's are in the plans)
Brakes: Baer Track/Touring
Suspension: Stock geometry with Hotchkis stuff, Koni shocks, PST bushings, CalTracs
...Well, you get the point. The list goes on. I did all the design and measuring while my cousin, Sean Burt of LG Motorsports, fabricated all the tubing and exhaust. It's just now running and preliminary dyno numbers are encouraging but there is still a ton of tuning to do. Once everything is dialed in it will come back apart for grinding and coating all the tubes.
I've been lurking around for a while and am also a member on Pro-Touring.com and several local Forums. I'm pleased to introduce myself and my car to you guys.
Old 01-05-2005, 01:28 PM
Hey, I know you! Welcome to the board and be sure and post more pics as they're available. The people here LOVE pics!
And yes, the preliminary pulls look very promising.
Old 01-05-2005, 01:31 PM
907rs's Avatar
907rs 907rs is offline
Welcome!
Thats one nice '68 you have there!
Bill
Keith's Avatar
Keith Keith is offline
Damn that car is beautiful, don't see too many turbo'ed carb applications....welcome!!
There's nothing more common than unsucessful men with talent
GENESIS CHEVELLE
Old 01-05-2005, 01:43 PM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
That car looks nasty.
Welcome to the crowd here.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
www.protouring.se www.carphotos.se
Old 01-05-2005, 02:22 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Wow!! Super nice car...Welcome to the site.
Jim
Old 01-05-2005, 03:05 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Awesome! How does it run with the blow through setup?
My LS7 69 Camaro
