Old 12-11-2009, 12:15 AM
LowchevyII's Avatar
LowchevyII LowchevyII is offline
Default fuel system for lsx
Im building a lq4 with the l92 heads and the fast 92mm intake (non drive by wire). Im going from a carbed small block to this and would like to knwo what i am going to need. Ideally i would like to change the entire system: tank, pump, filter, pre filter, lines, etc.
What do you guys recommend as my best options?
I would like to maybe go with an aluminum cell (http://www.summitracing.com/parts/SU...D/?image=large) because i am gonna be mini tubbing but cannot afford to spend over a grand and a narrowed stainless tank if i can avoid it i would like to.
Comments suggestions and pictures are greatly appreciated
thanks in advance,
Jeff
Jeff Weidner
1970 nova in pieces
Old 12-11-2009, 07:59 AM
reckn8 reckn8 is offline
I think that you should start by reading here...
https://lateral-g.net/forums/showthread.php4?t=23304
Old 12-11-2009, 12:19 PM
70rs's Avatar
70rs 70rs is offline
Ricks is having a really good sale right now on tanks. They just posted in the Sponsor News section. Take a look, maybe that stainless tank is within reach now? The motor plan sounds great. You should end up with a stout and reliable motor.
Old 12-11-2009, 04:29 PM
LowchevyII's Avatar
yeah, im hoping for something cheap reliable but with some grunt that can keep up. i cant wait to get all this planned out and just start chipping away at what needs to be done
Jeff Weidner
1970 nova in pieces
Old 12-11-2009, 07:04 PM
1badchevelle 1badchevelle is offline
Maybe this will help.
on the fuel pump most use the walbo gsl-392 but for a bit more a good upgrade is the bosch 044 or(#0 580 254 044)
let me know if you need more info.
Old 12-11-2009, 08:19 PM
70rs's Avatar
Frank also just posted a sale on Ricks tanks. LOTS of free upgrades and other things included. Just over a grand gets you the best available. Great savings right now.
Old 01-06-2010, 10:09 AM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Do you have a bigger version of that diagram (the part numbers are a little hard to read)?
Old 01-06-2010, 09:34 AM
sharonk868 sharonk868 is offline
Banned
thanks in advance,
Jeff
Thanks you for the post.
Hi guys, Im a newbie. Nice to join this forum.
