Old 01-11-2010, 02:35 AM
Default 1968 Pro Touring Procharged Camaro "Vertigo" for sale
It was with much sadness that I post this car for sale after a 3+ year journey with lots of ups and downs along the way.
What started as a simple driver Camaro build evolved into a full pro touring tire shredder with up to 800 crank horsepower on tap. I was always one to say I just wanted the car to be done so I could enjoy it, but I actually did enjoy the roller coaster ride of the build and the many friends I made along the way.
Business issues force this sale. We actually had record sales in 09 but when 2 of your largest clients cannot pay you this is what happens. I vow to be back in a bad ass muscle car sooner rather than later.
The car has less than 300 miles on the odometer since the build was completed, and most of that was the weekend trip from Sacramento to Pleasanton for the Goodguys Autumn Get Together, where this car won Cool Camaro award in a sea of Camaros. I was pretty proud of that award.
The motor is currently being refreshed with new pistons, rings, bearings, and gaskets and will be installed back in the car in the following couple weeks. Car is at Gearhead Garage in Sacramento and can be viewed during business hours there. Jason can answer pretty much every question you have there, and if not, ask me. Most answers can be found on my website or viewing the parts list below.
If no bites here, it will be going to ebay shortly. Lots of stalled projects for sale right now I know. This is a turnkey car with all parts brand new or having a couple hundred miles. Come buy it and drive it away.
Asking $62,000. Like most of these builds, you know there is a helluva lot more invested in this car than that price.
Email dwgordon at gmail dot com or call 415-314-8000.
http://www.vertigocamaro.com
http://picasaweb.google.com/dwgordon/68Camaro
PPG Deltron 2000 BMW Sterling Gray paint
smoothed firewall
Auto Meter gauges with custom lower dash console gauge housing
push button start
406 cubic inch small block (dyno 700 rear wheel horsepower)
Factory 400 2-bolt block with partial fill
Eagle 4340 steel 3.75" crank
Eagle 4340 steel 6" H-beam rods
Ross custom blower pistons
Speed Pro Plasma rings
Milodon 7 quart pan
Cloyes true roller chain
Comp Cams hydraulic roller blower cam and lifters (244/252 @ .050, .620/.620 lift, 114 LSA)
AFR rev kit
Victor Jr. heads with Stage IV port by CFM Performance
Crower stainless 1.6 roller rockers
Holley Stealth Ram intake manifold and 1000cfm throttle body
MSD 72# injectors
MSD 6AL ignition
MSD Blaster 2 coil
MSD 85551 billet distributor with GM melonized gear
MSD 8mm wires
D1SC ProCharger
Custom billet ProCharger spacer bracket
ProCharger brackets, pulleys for water pump and power steering pump
McLeod aluminum 168 tooth flywheel with steel insert
Edelbrock Victor aluminum water pump
GM Performance cast aluminum valve covers
FAST EFI and harness
Keisler Engineering TKO 600 5-speed transmission
3" 1053 steel driveshaft with 1350 yokes
McLeod scattershield
Currie Ford 9" rear with 3.70 gears
Hotchkis front sway bar
Wilwood disc brakes front & rear:
13" rotors/6 piston fronts
12" rotors/4 piston rears
Unisteer rack and pinion steering
Flaming River stainless steel tilt steering column
Flaming River Waterfall steering wheel
QA1 adjustable coilover shocks
Air Ride Technologies Air Bar 4 link rear suspension
Mini-tubbed
Air Ride Technologies Strong Arm upper/lower control arms
Hydraboost brake booster
Custom stainless steel 1-3/4" to 1-7/8" stepped headers with Cape's high temp coating
Stainless Works 3 inch mandrel bent exhaust
Magnaflow X-pipe
Spintech Sportsman XL mufflers
Modo Innovations pedal kit
Modo Innovations electric trunk release
Treadstone Intercooler with 3 inch mandrel bent 304 stainless plumbing
Cyclone Rods radiator with dual Spal fans
Mach 1 gas cap
Esajian Wheels forged alloy 2 piece wheels
powdercoated matte black centers and lips
18x9 front with 6.25" backspacing
18x12 rear with 6" backspacing
Nitto 555 tires front - 275/35/18
Nitto 555R tires rear - 335/30/18
ISS bucket seats with leather upholstery and microsuede inserts
Marquez Design 1969 RS tail lights
Twist Machine fender braces
Twist Machine shifter
American Autowire harness
Rick’s narrowed stainless steel fuel tank
Bosch 044 fuel pump mounted in-tank
Billet Specialties battery mount tray
Optima Battery
Wilwood master cylinder
Corbeau lap belts
Ring Brothers hood hinges
Lokar shift boot and trim ring
Detroit Speed 7 speed wiper kit
PSC power steering reservoir
Safecraft 2.5 lb fire extinguisher
Old 01-11-2010, 06:40 AM
fleet's Avatar
fleet fleet is offline
I wish you well in the sale Dave.
With its great stance this first pic reminds me of a Trans-Am car.
Old 01-11-2010, 09:39 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Sorry to hear about your situation Dave.
I wish you all the best and good luck with the sale.
Old 01-11-2010, 10:00 AM
Thank you guys. And thanks for posting those pics Skip.
Old 01-11-2010, 10:30 AM
fleet's Avatar
You're welcome Dave.
I'm glad to finally be able to use my education to help someone. http://www.post.edu/
Old 01-11-2010, 10:32 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
NOOOoooooo!!!!!!!
Curtis
Old 01-11-2010, 04:53 PM
NOOOoooooo!!!!!!!
I'm afraid so.
Old 01-11-2010, 08:40 PM
eqt555 eqt555 is offline
Dude,
I cant believe youre selling your car. Actually, youre puking your car at that price. Im just at the end of my build, and Ive been pratically bled dry and my wife hates me. I can only pray for luck that nothing catastrophic happens to my family or to anyone else in this sport, the pain is too great after so much time and effort to see a project through to the end. There is one reason and one reason only that I have my particular shifter in my car, and thats because I saw it in your car. I cant even imagine how bad this has to hurt, and I hope the money you get goes a long way. I hope it makes you succesful enough to help you come back to this sport soon, pal!
Old 01-11-2010, 10:31 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Can't tell you how bad this sucks----So, we probably won't be seeing you in June then--we were all looking forward to that---nonetheless, good luck with the sale bro--
Doug
Old 01-11-2010, 10:36 PM
Thanks you guys. As much as it sucks to have to put this up for sale, it makes me feel warm and fuzzy to read the supportive comments and best wishes on here because I know they are very sincere.
This will absolutely not be my final muscle car. That I can assure.
I am subscribing to the school of thought that everything happens for a reason. We'll see how it all turns out.
Thanks again guys. I was really looking forward to meeting up with many of you on a cruise thrash session. Hopefully that day may still come.
