Old 03-25-2010, 02:22 PM
68 454 EFI's Avatar
68 454 EFI 68 454 EFI is offline
Default Power brakes or Manual?
Hey,
New to this site, just looking for some friendly advice. I have a 68 Camaro that is currently 4 wheel drum. I'm looking to atleast upgrade the front braking system to disc. I have heard that running 4 wheel disc brakes is a bad idea when the car sits for more than 6 months at a time as the rear calipers have a tendancy to seize? Also, i would like to get rid of the brake booster for esthetic reason's but i'm not sure if manual brakes are going to be good enough. The car has a fuel injected 454 which makes very little vaccume at idle. Seems like gettting rid of the power brakes and going with a decent manual set up is the best option. Any comments or suggestions is greatly appreciated.
Old 03-25-2010, 02:30 PM
6spdcamaro 6spdcamaro is offline
hydroboost runs off of the power steering pump so you don't need a lot of vacuum. It also looks nicer than a vacuum booster. They are on the top left of the screen. Hydratech braking systems
Ken
Old 03-25-2010, 02:31 PM
Manual brakes work GREAT -- and there's no good reason to run power brakes. The key to good manual brakes is the proper master cylinder for your combination - and the pedal ratio. If I was doing disc front drum rear - I'd run a 1" wilwood master cylinder - and a 6 or 7:1 pedal ratio.
Power brakes are 4:1 pedal ratio.
Talk to the boys at KORE3 - Just google it... and see what they advise you.
Old 03-26-2010, 03:40 PM
68 454 EFI's Avatar
Thanks for the advise, I think i'm definitely going to go with the manual set up. Just gotta find the best deal, on the best set up. Thanks again guys.
Old 03-26-2010, 04:31 PM
JustinB's Avatar
JustinB JustinB is offline
BBC with very little vacuum and running a manual Wilwood front/rear setup with a 7/8 bore master. Hit the pedal hard and if you are not paying attention and you will bury yourself into the steering wheel. We have a number of kits that we can offer you. Feel free to call, PM, or email for pricing and info.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 03-26-2010, 05:55 PM
How well the manual brakes work depends a lot on how the system was designed. If you use a system that was designed as a power assist system, there is a delicate line in getting the volume / pressure right. A system like Wilwood will work great as a manual system because it is designed to be a manual system, but you can run power assist if you choose.
We sell more then half our Wilwood Total Car G Machine Brake packages as manual systems as many of our cars and customers cars are big HP, big cam, or blown turbo / blower cars, that make little vacuum.
It gets a little tricky with getting proper pedal feel and volume with disc / drums. The small bore / high pressure master does not work great with disc / drum set ups. A larger bore works much better for volume but makes for a fairly firm pedal. So it really becomes a one or the other situation.
I could talk for hours on the subject. But I type with 2 fingers, LOL!
Frank Serafine
Old 04-22-2010, 05:19 PM
Taman Taman is offline
Default pedal ratio
How do you change the pedal ratio on a 2nd gen TA?
Old 04-22-2010, 09:29 PM
I'd second that thought -- My 7/8" Wilwood manual master / Baer brake (disc all 4)... will throw you right thru the window if you want them to ---- and for driving around town - they require very little effort.
