Old 04-26-2010, 06:41 PM
brans72 brans72 is offline
Default ? on power window install
I was wondering if I want to install power windows on a non powe window car should I do before or after painting car? I am leaning toward Electric Life but looking a budget and time frame for buying/installing. Brandon
Old 04-26-2010, 07:29 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I installed my Electric Life stuff after the car was painted. It was cake... but they sure are wimpy. If I could have run manual windows, I would have, but the cranks wouldn't clear the Marquez door panels.
My LS7 69 Camaro
Old 04-26-2010, 09:28 PM
It's no problem installing power windows after paint.
I've done it a couple of times - and there's nothing with the paint on the exterior -- EXCEPT the door looms... but even then - you can run the loom without messing up the paint. It's just easier of course - to have the holes for the looms done with the door off the car.
Old 04-26-2010, 10:53 PM
skatinjay27's Avatar
damn scott that scares me to try them for my car since the 2nd gen windows are quite larger... is there any other companys with better motors out there?
AJ
Old 04-27-2010, 03:04 AM
You trying to get me to think twice Scott? I have stock manual window still in the garage. I figured power would be nice but maybe we should poll this ? Brandon
Old 04-27-2010, 07:03 AM
I'd be checking the grounds.. they should NOT be "wimpy".
I have power windows in 3 different hot rods -- and they work GREAT.
Old 04-27-2010, 07:36 AM
camcojb camcojb is online now
I removed the power windows in my Chevelle for the same reason Scott mentioned. If you open the door they were fine to roll up, but with the door shut the motors are set to stop way before they compress the rubber glass seals at the top and sides............. (speaking of the built in torque limits of the motors, not the actual height the window goes which is adjustable).
You know how on these older cars with manual window cranks you need to roll the window up into the rubber seal and give it just a little "oommph"..... the electric life units won't do that, as soon as they meet "X" amount of resistance the motors stop. If that was adjustable you could probably solve the issue. I know Scott just opens his door when the window is going all the way up, but to be correct you shouldn't have to do that. Had the same issue with the rear 1/4 windows, as they rub the rubber channel on the top and rear as they go up. If I sprayed Windex on the rubber the windows would go all the way up................ as soon as it dried again they would not go to the top. I removed and sold mine, went back to manual.
