Old 08-03-2010, 12:41 AM
T-Type T-Type is offline
Arrow Frame Sandblasting at Home/Prep for Paint and strengthening?
hi guys. well looking for some advise. i finally found an impala frame that came off a 61 and it's in pretty good shape. i'm going to be building a sealed shelter to house it in while it gets worked on and am looking at doing the sand blasting at home. the plan is to rent a blaster and go to work once the frame is all apart and bare.
what i'm wondering is what grit sand should i use for the frame? i know sandblasters can be rented....what about media blasters? i guess in the end the result i want is a bare frame with all the rust gone and weak spots in need of attention revealed.
what is the best route to take?
edit- please see further questions on second page.
Old 08-03-2010, 02:17 AM
deuce_454's Avatar
imho, have a pro do it... a frame is a big job and if you want it done perfectly i would clean it yoursel first, finish all the welding and so on.. and then have it blasted and powdercoated professionally..
it will add more to the final value that its done right.. and you can keep your work area clean from sand....
Jake: Hit it.
Old 08-03-2010, 05:07 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I had my whole frame blasted for $150.
By the time you rent one, get sand, have a good respirator, and full suit, sweat your azz off, waste a day, etc. etc. it's just not worth it.
Have it done.
Old 08-03-2010, 06:28 AM
jy211's Avatar
jy211 jy211 is offline
YUP. What the guys said above. Cheaper and faster to have a pro company do it!
Old 08-03-2010, 10:25 AM
rwhite692's Avatar
I also would strongly recommend having the frame blasted by a local shop. I once did a 1960 Cadillac frame (big X-type frame) in my backyard in NY using a pressure pot sand blaster and man, that was no fun. It takes a lot longer than you think it will.
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 08-03-2010, 08:28 PM
kochevy67's Avatar
kochevy67 kochevy67 is offline
Send it out, the only thing I disagree with is the powder coating. It chips and your screwed. Paint it you canalways touch it up. I'm sure you will hear guys tell you powder doesn't chip, well let me tell you it does.
