Old 09-19-2010, 10:18 AM
wrighton wrighton is offline
Default Mini Tub Rear Seat Narrowing
I am curious if any body can put up some pictures of Rear Seats or the process with measurements to narrow a stock 68 camaro rear seat to fit the mini tubs. Thank you for any imput.
Old 10-11-2010, 11:55 PM
redz redz is offline
Get some round bars at the hardware store. It cost me $12. Starting with the seat back, you need to add one vertical bar and 3 "S" shaped horizontal bars on each side and then cut off the old bars to make room for the larger wheel well. Place the vertical bar in the depression of the existing springs. Make sure you put wet towels down before you weld. The old padding burns very easily. The seat bottom is more of a challenge. There is one wire that needs 3 clips undone. The wire needs to be bent with vise grips and then re attach the 3 clips in the new position. I found my welding pliers worked the best on opening these clips. Cut the two wiggly springs after you have re attached the wire. Add 2 bars and then cut off the corner of the frame.
BTC
The Following 4 Users Say Thank You to redz For This Useful Post:
572Camaro (01-24-2021), 68454RS (01-25-2021), Rodknock (03-25-2020), WILWAXU (04-27-2020)
Old 10-16-2010, 10:07 PM
Richio1's Avatar
Richio1 Richio1 is offline
Talking
This is awesome... thank you for posting the detailed pics. I needed this info too so this is perfect. I will be doing mine in a month or two.
Thanks!
Old 11-26-2010, 03:14 PM
JB69ER JB69ER is offline
Great Pictures And Info.
Now If I Can Make Mine Folding Also, All Will Be Good!!! THEY DID THIS ON MUSCLE CARS SEVERAL YEARS AGO..
ALSO THAT ROD LOOKS LIKE "PENCIL ROD" = SMALL 1/4 - 5/16 NON-DEFORMED RE-BAR USED WITH BRICKWORK,
AVAILABLE AT A MASONRY SUPPLY YARD.
Old 11-27-2010, 12:02 AM
holschen's Avatar
holschen holschen is offline
thanks this is great info
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 11-27-2010, 10:22 PM
I used 8' of 1/4" rod and 4' of 5/16" rod. Costs about $12 at the hardware store.
Old 02-01-2019, 06:35 PM
71-Formula's Avatar
71-Formula 71-Formula is offline
Old 03-25-2020, 10:25 PM
Rodknock's Avatar
Rodknock Rodknock is offline
Originally Posted by 71-Formula View Post
Narrowed TMI seats? That's what I'm looking at doing for mine
John Rodko
69 Camaro RS/SS
Rolling shell, minimal rust.
Heidts Pro G IRS/ Heidts Pro G Front
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
https://www.facebook.com/Angry-Johnn...?ref=bookmarks
Old 04-27-2020, 10:19 AM
cmb396 cmb396 is offline
Can these be ordered from TMI like this, or do you have to order standard size and make it fit?
Old 04-28-2020, 09:39 AM
Rodknock's Avatar
I called TMI, and they said you have to order standard and narrow them yourself. They said, too many variables in mini tub styles to make one seat fit all.
John Rodko
69 Camaro RS/SS
DSE mini tubs
FUTURE PLANS:
T-56
Twin Turbo 6.0L
The Following User Says Thank You to Rodknock For This Useful Post:
cmb396 (04-29-2020)
