Old 01-04-2011, 03:36 PM
Moabdude's Avatar
Moabdude Moabdude is offline
Default Fusing the alternator-battery
I have my Optima battery in the trunk. I have one thick wire from the alternator (100amp) directly to my battery. Do I fuse the battery at 100amps?
Seems logical but I am not sure.
>68 Camaro pro touring, 400SBC, 18" Intro's, T4 13" Baer Eradispeed, Airride, Speedtech, Autometer, König seats, March, Magnaflow. Hope to finish in 2006...2007...2008…2009...2010...2011...Yes, 2012 and its finished (well, will it ever be finished )
>69 Nova project, LS1/4L60e, Corvette C5 calipers+rotors, AFX spindles, 69 Camaro body mods, Just got it painted.
Old 01-04-2011, 06:23 PM
No need to fuse the alt to battery - the alt already has a built in regulator. It'll never put a 100 amps into the battery - the battery wouldn't allow that. Batteries really charge on VOLTAGE not really amperage and the regulator in the alt is voltage based.... so you're good.
A circuit breaker or fusible link from the battery to the STARTER isn't a bad idea - although you rarely see anyone do that.
Some wiring harnesses are shipped with fusible links in the ALT to Battery connection but most of those run thru the "fuse box"....
Old 01-04-2011, 06:42 PM
BBC69Camaro's Avatar
Hey Greg,
You know of any Circuit breakers that can handle cranking amperage on car batteries?
Doing my electrical system now couldn't find anything other than really Mad Electrical's Ford Solenoid, so at least the starter cable is only hot during cranking.
Old 01-04-2011, 07:15 PM
shadow images shadow images is offline
When I rear mount batteries I will use a 100amp 12v breaker near the batt for the alternator feed. Great if for some reason the wire rubs through or when you need to service the alternator you can trip the breaker.
Old 01-04-2011, 06:30 PM
youthpastor's Avatar
I go from the Alt to the starter on the Battery side
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
