Old 02-04-2011, 07:29 AM
ed1le ed1le is offline
Default 355 sbc, accessories & Centerforce Flywheel
355 – 010 casting, 2-bolt main
Hypereutectic Flat tops, Powerhouse remanufactured small valve heads
Crane cam
Crane Blazer 1.5 roller rockers
Edelbrock RPM intake
Noisy Gear Drive
Edelbrock 2-piece aluminum timing cover
7qt deep sump oil pan & hi-volume oil pump
Billet tall valve covers & water neck
New stock long water pump
Under 500 miles on engine. My buddy built this a few years ago for his daily driver but sold the car before installing it. It was installed in his brothers truck for break-in and driven locally a few times but that was it. I bought it off him and installed it in my Skylark but never fired it. Buying an LT1 so it needs to go. I have kept it oiled and turned it over by hand regularly to keep it lubed. Don't recall cam specs but in the 220/.460 range I believe. I do know he was shooting for 300hp & 375ft lb and is very meticulous w/ his builds. asking $600
(old edelbrocks on it now were just to make sure the good ones didn't get scratched when installing)
Centerforce flywheel, #CTF-700107 for t56/2-piece sbc
Bought w/ approx. 8K miles (I believe from someone on here or LS1tech.com), I had it resurfaced, hasn't been used since. Retails for $410, asking $300
Summit 600 carburetor - New, installed but never run. Still have box & everything that goes with it (cost $260). Will include ProComp billet spring/cable bracket & Spectre dual feed fuel line w/ gauge (cost about $30 each). asking $250
Summit 100 amp 1-wire alternator, powder coated black w/ Summit billet brackets - New, alt was $80 & brackets were $40, asking $80
Type II P/S pump w/ reservoir w/ brackets & aluminum pulley - pump is new, brackets & pulley have some nicks but probably from sitting around, bracket missing a couple bolts as well but nothing you couldn't get from a hardware store. Pump alone retails for $150 and Summit has bracket for $110 bought last month from someone on LateralG.net for $150, for use w/ long pump, asking $150
Summit Billet water pump (single groove-$36 retail) and Crank (double groove- $50 retail) pulleys - new, asking $50
Summit billet water pump (double groove-$50 retail) and Crank (triple groove-$53 retail) pulleys –new, asking $50
Jegs mechanical fuel pump (80gph) - new, installed on engine but never run, cost $50, asking $30
Procomp HEI w/ coil & cap - new, cost around $100, asking $75
Will post pics of everything tonight. Thanks.
1987 Iroc, ZZ4, TPIS Mini Ram, TFS heads, custom cam, T56, 3.73's, C5 brakes, 17" Centerlines, Full Hotchkis/Koni Suspenion
1970 Skylark Convertible Pro-Touring project- on hold
Old 02-04-2011, 09:06 AM
Roberts68 Roberts68 is offline
These may work for me. I'd like to see pics and verify if they are what I need for grooves and where. I think this is right.
Summit-style billet water pump (double groove-$50 retail) and Crank (triple groove-$53 retail) pulleys –like new, asking $50
Part number by chance?
Old 02-04-2011, 09:16 AM
I'll post picks of everything tonight.
Fuel pump # 15950, $45 (not $50-was going off memory) I believe I have fittings for the pump as well that I can include.
http://www.jegs.com/i/JEGS-Performan...oductId=759861
Old 02-04-2011, 10:48 AM
Might be interested in this too.
Type II P/S pump w/ reservoir w/ brackets & aluminum pulley - pump is new, brackets & pulley have some nicks but probably from sitting around, bracket missing a couple bolts as well but nothing you couldn't get from a hardware store. Pump alone retails for $150 and Summit has bracket for $110 bought last month from someone on here for $150, asking $150
Was this a lower drivers side location mount and do you know if it was long or short water pump? Mine is a short water pump.
Old 02-04-2011, 10:58 AM
Lower Drivers side, long pump.
Old 02-04-2011, 01:51 PM
Pictures added.
